Fehler im Log beim Laden der Startseite
ich Log taucht immer der folgende Fehler auf:
SmartyException: Unable to load template snippet 'frontend/home/index.tpl|frontend/plugins/seo/index.tpl' in /engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php:127 Stack trace:
#0 /engine/Library/Enlight/View/Default.php(291): Smarty_Internal_TemplateBase->fetch()
#1 /engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(180): Enlight_View_Default->render(Object(Enlight_Template_Default))
#2 /engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(207): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default))
#3 /engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(124): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render()
#4 /engine/Library/Enlight/Event/Handler/Default.php(90): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Controller_ActionEventArgs))
#5 /engine/Library/Enlight/Event/EventManager.php(208): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs))
#6 /engine/Library/Enlight/Controller/Action.php(224): Enlight_Event_EventManager->notify('Enlight_Control...', Object(Enlight_Controller_ActionEventArgs))
#7 /engine/Library/Enlight/Controller/Dispatcher/Default.php(461): Enlight_Controller_Action->dispatch('indexAction')
#8 /engine/Library/Enlight/Controller/Front.php(225): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#9 /engine/Shopware/Kernel.php(197): Enlight_Controller_Front->dispatch()
#10 /vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(85): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#11 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(479): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
#12 /engine/Shopware/Components/HttpCache/AppCache.php(262): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#13 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(269): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#14 /engine/Shopware/Components/HttpCache/AppCache.php(103): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#15 /www/htdocs/xxx/xxx/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
Hatte das jemand auch schon einmal?
Ich verwende Shopware Version 5.7.6
Die Dateien frontend/home/index.tpl und frontend/plugins/seo/index.tpl sind original von Shopware und liegen unter dem Bare Theme.
Florian
