Hallo Ich bekomme immer wieder diesen Fehler per Mail-Log zugestellt. Hat jemand eine Ahnung wie man den beheben kann und was er bedeutet? Kann das trotzdem ein Bot sein, obwohl “Bot: false” steht? Besten Dank im Voraus für die Hilfe. Marco Message: exception ‘SmartyException’ with message ‘Unable to load template snippet ‘frontend/account/ajax_login.tpl|frontend/plugins/seo/index.tpl’’ in /home/…/public_html/engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php:127 Stack trace: #0 /home/…/public_html/engine/Library/Enlight/View/Default.php(274): Smarty_Internal_TemplateBase->fetch() #1 /home/…/public_html/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight_View_Default->render(Object(Enlight_Template_Default)) #2 /home/…/public_html/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default)) #3 /home/…/public_html/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render() #4 [internal function]: Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Controller_ActionEventArgs)) #5 /home/…/public_html/engine/Library/Enlight/Event/Handler/Default.php(91): call_user_func(Array, Object(Enlight_Controller_ActionEventArgs)) #6 /home/…/public_html/engine/Library/Enlight/Event/EventManager.php(211): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs)) #7 /home/…/public_html/engine/Library/Enlight/Controller/Action.php(202): Enlight_Event_EventManager->notify(‘Enlight_Control…’, Object(Enlight_Controller_ActionEventArgs)) #8 /home/…/public_html/engine/Library/Enlight/Controller/Dispatcher/Default.php(524): Enlight_Controller_Action->dispatch(‘ajaxLoginAction’) #9 /home/…/public_html/engine/Library/Enlight/Controller/Front.php(227): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #10 /home/…/public_html/engine/Shopware/Kernel.php(143): Enlight_Controller_Front->dispatch() #11 /home/…/public_html/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 /home/…/public_html/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #13 /home/…/public_html/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(447): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #14 /home/…/public_html/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(347): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #15 /home/…/public_html/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #16 /home/…/public_html/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(211): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #17 /home/…/public_html/engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #18 /home/…/public_html/shopware.php(101): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #19 {main} Time: 2015-06-08T07:15:13.022014+0200 Channel: core request: { “uri”: “/account/ajax_login”, “method”: “GET”, “query”: { “module”: “frontend”, “controller”: “account”, “action”: “ajax_login” }, “post”: } session: { “sessionId”: “aea466f51a63867a0630331ec86a6e660081765d”, “Bot”: false, “sOutputNet”: false, “sRegister”: , “sCountry”: null, “sState”: null, “sPaymentID”: null, “sBasketQuantity”: null, “sBasketAmount”: null, “tpfPaymentData”: null, “sUserId”: null } shopId: 1 shopName: Deutsch
Hallo Zusammen niemand eine Idee, was das sein könnte und wie man es behebt? Bei mir kommt die Meldung immer im Doppel, also 2 identische Fehlermeldungen zur fast exakt gleichen Zeit: Time: 2015-07-08T04:15:14.118689+0200 Time: 2015-07-08T04:15:26.013356+0200 Auch jemand anders scheint diese Fehlermeldung zu bekommen: allgemein-f98/seltsamer-fehler-in-logs-core-error-exception-smarty-t28935.html Cheers Marco
Seit Tagen werde ich mit gleichen Fehlermeldungen via E-Mail bombardiert: exception ‚SmartyException‘ with message ‚Unable to load template snippet ‚frontend/account/ajax_login.tpl|frontend/plugins/advanced_menu/index.tpl|frontend/plugins/swag_cookie_permission/index.tpl|frontend/plugins/seo/index.tpl|frontend/plugins/swag_piwik/index.tpl‘‘ in /var/www/deinefashion.de/html/engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php:127 Stack trace: #0 /var/www/deinefashion.de/html/engine/Library/Enlight/View/Default.php(274): Smarty_Internal_TemplateBase->fetch() #1 /var/www/deinefashion.de/html/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(216): Enlight_View_Default->render(Object(Enlight_Template_Default)) #2 /var/www/deinefashion.de/html/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(242): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate(Object(Enlight_Template_Default)) #3 /var/www/deinefashion.de/html/engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(136): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render() #4 [internal function]: Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch(Object(Enlight_Controller_ActionEventArgs)) #5 /var/www/deinefashion.de/html/engine/Library/Enlight/Event/Handler/Default.php(91): call_user_func(Array, Object(Enlight_Controller_ActionEventArgs)) #6 /var/www/deinefashion.de/html/engine/Library/Enlight/Event/EventManager.php(211): Enlight_Event_Handler_Default->execute(Object(Enlight_Controller_ActionEventArgs)) #7 /var/www/deinefashion.de/html/engine/Library/Enlight/Controller/Action.php(202): Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Object(Enlight_Controller_ActionEventArgs)) #8 /var/www/deinefashion.de/html/engine/Library/Enlight/Controller/Dispatcher/Default.php(524): Enlight_Controller_Action->dispatch(‚ajaxLoginAction‘) #9 /var/www/deinefashion.de/html/engine/Library/Enlight/Controller/Front.php(227): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #10 /var/www/deinefashion.de/html/engine/Shopware/Kernel.php(143): Enlight_Controller_Front->dispatch() #11 /var/www/deinefashion.de/html/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(490): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #12 /var/www/deinefashion.de/html/engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #13 /var/www/deinefashion.de/html/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(447): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #14 /var/www/deinefashion.de/html/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(347): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #15 /var/www/deinefashion.de/html/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #16 /var/www/deinefashion.de/html/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(211): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #17 /var/www/deinefashion.de/html/engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #18 /var/www/deinefashion.de/html/shopware.php(101): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #19 {main} Time: 2015-09-21T17:14:12.733756+0200 Channel: core request: { „uri“: „/account/ajax_login“, „method“: „GET“, „query“: { „module“: „frontend“, „controller“: „account“, „action“: „ajax_login“ }, „post“: } session: { „sessionId“: „5f5d46f1fee1b6236dde409bb67dc0c845729182“, „Bot“: true, „sOutputNet“: false, „sRegister“: , „sCountry“: null, „sState“: null } shopId: 1 shopName: DeineFashion
Bei mir hats sich gelegt. Hast du erst kürzlich auf Shopware gewechselt und relativ viele neue URLs?
