Export-Feeds
Bei meinen Export-Feeds werden die Bilder teilweise ohne das " am ende exportiert und mit |,
Hat jemand eine Idee an was kann das liegen kann ?
Mein Template:
{assign var="string" value=$sArticle.articleID|articleImages:$sArticle.ordernumber:2:"##"|escape}
{assign var="productVariantImage" value="##"|explode:$string}
{if $sArticle.additionaltext}
{if $sArticle.standard && $sArticle.additionaltext}
{strip}
{if $sArticle.standard}#{$sArticle.articleID}{else}{/if}|
{if $sArticle.standard} {else} {if $sArticle.additionaltext}#{$sArticle.articleID}{else}{/if}{/if}|
{if $sArticle.standard}{else}{$sArticle.additionaltext|replace:"|":" "}{/if}|
Variante|
{$sArticle.configurator}|
{$sArticle.ordernumber}|
{$sArticle.suppliernumber}|
{$sArticle.ean}|
{$sArticle.name}|
{$sArticle.price|format:"number" }|
{$sArticle.mainDetailId} |
{if $sArticle.referenceunit && $sArticle.purchaseunit}
{assign var="sArticleReferenceprice" value=$sArticle.price/$sArticle.purchaseunit*$sArticle.referenceunit}
{$sArticle.unit}|
{$sArticle.purchaseunit}|
{else}
{/if}
1|
{$sArticle.purchasesteps} |
{$sArticle.instock} |
{$sArticle.shippingtime} |
{$sArticle.minpurchase} |
{$sArticle.active} |
{$sArticle.supplier} |
{$sArticle.description_long|strip|replace:"|":""|escape}|
{$sArticle.articleID|category:" > "|escape}|
{$productVariantImage[0]}|
{$productVariantImage[1]}|
{$productVariantImage[2]}|
{$productVariantImage[3]}|
{$productVariantImage[4]}|
{#L#}{/strip}{/if}{if $sArticle.additionaltext}{strip}
{if $sArticle.ordernumber == "100448-0340G-SF"}{elseif $sArticle.standard}{else}{/if}|
{if $sArticle.additionaltext}#{$sArticle.articleID}{else}{/if}|
{$sArticle.additionaltext|replace:"|":" "}|
Variante|
{$sArticle.suppliernumber} |
{$sArticle.ean} |
{$sArticle.name} |
{$sArticle.price|format:"number" } |
{$sArticle.unit}|
{else}
{/if}
1|
{if $sArticle.additionaltext}{else}{$sArticle.description_long|strip|replace:"|":""|escape}|{/if}|
{#L#}{/strip}{/if}
{else}
{strip}
{$sArticle.ean}|
{$sArticle.name}|
{$sArticle.unit}|
{else}
{/if}
1|
{#L#}{/strip}{/if}
