Error Message Installation
ich komme bei meiner lokalen Installatin (xampp) nicht weiter. Wo kann der Fehler liegen?
Error
Received an error message.
URL: importDatabase
Message: Internal Server Error
Response
Slim Application Error
Type: Error
Message: Class 'Symfony\Component\HttpKernel\Exception\HttpException' not found
File: /opt/lampp/htdocs/sw6/vendor/shopware/core/Framework/ShopwareHttpException.php
Line: 8
Trace
#0 /opt/lampp/htdocs/sw6/vendor/shopware/recovery/Common/vendor/composer/ClassLoader.php(444): include()
#1 /opt/lampp/htdocs/sw6/vendor/shopware/recovery/Common/vendor/composer/ClassLoader.php(322): Composer\Autoload\includeFile('/opt/lampp/htdo...')
#2 [internal function]: Composer\Autoload\ClassLoader->loadClass('Shopware\\Core\\F...')
#3 /opt/lampp/htdocs/sw6/vendor/shopware/core/Framework/Migration/Exception/InvalidMigrationClassException.php(7): spl_autoload_call('Shopware\\Core\\F...')
#4 /opt/lampp/htdocs/sw6/vendor/shopware/recovery/Common/vendor/composer/ClassLoader.php(444): include('/opt/lampp/htdo...')
#5 /opt/lampp/htdocs/sw6/vendor/shopware/recovery/Common/vendor/composer/ClassLoader.php(322): Composer\Autoload\includeFile('/opt/lampp/htdo...')
#6 [internal function]: Composer\Autoload\ClassLoader->loadClass('Shopware\\Core\\F...')
#7 /opt/lampp/htdocs/sw6/vendor/shopware/core/Framework/Migration/MigrationCollection.php(145): spl_autoload_call('Shopware\\Core\\F...')
#8 /opt/lampp/htdocs/sw6/vendor/shopware/core/Framework/Migration/MigrationCollection.php(121): Shopware\Core\Framework\Migration\MigrationCollection->loadMigrationSteps()
#9 /opt/lampp/htdocs/sw6/vendor/shopware/core/Framework/Migration/MigrationCollection.php(95): Shopware\Core\Framework\Migration\MigrationCollection->ensureStepsLoaded()
#10 /opt/lampp/htdocs/sw6/vendor/shopware/core/Framework/Migration/MigrationCollection.php(50): Shopware\Core\Framework\Migration\MigrationCollection->getMigrationSteps()
#11 /opt/lampp/htdocs/sw6/vendor/shopware/recovery/Install/src/app.php(596): Shopware\Core\Framework\Migration\MigrationCollection->sync()
#12 [internal function]: Closure->{closure}(Object(Slim\Http\Request), Object(Slim\Http\Response), Array)
#13 /opt/lampp/htdocs/sw6/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(40): call_user_func(Object(Closure), Object(Slim\Http\Request), Object(Slim\Http\Response), Array)
#14 /opt/lampp/htdocs/sw6/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/Route.php(281): Slim\Handlers\Strategies\RequestResponse->__invoke(Object(Closure), Object(Slim\Http\Request), Object(Slim\Http\Response), Array)
#15 /opt/lampp/htdocs/sw6/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/MiddlewareAwareTrait.php(117): Slim\Route->__invoke(Object(Slim\Http\Request), Object(Slim\Http\Response))
#16 /opt/lampp/htdocs/sw6/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/Route.php(268): Slim\Route->callMiddlewareStack(Object(Slim\Http\Request), Object(Slim\Http\Response))
#17 /opt/lampp/htdocs/sw6/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/App.php(503): Slim\Route->run(Object(Slim\Http\Request), Object(Slim\Http\Response))
#18 /opt/lampp/htdocs/sw6/vendor/shopware/recovery/Install/src/app.php(160): Slim\App->__invoke(Object(Slim\Http\Request), Object(Slim\Http\Response))
#19 [internal function]: Closure->{closure}(Object(Slim\Http\Request), Object(Slim\Http\Response), Object(Slim\App))
#20 /opt/lampp/htdocs/sw6/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/DeferredCallable.php(57): call_user_func_array(Object(Closure), Array)
#21 [internal function]: Slim\DeferredCallable->__invoke(Object(Slim\Http\Request), Object(Slim\Http\Response), Object(Slim\App))
#22 /opt/lampp/htdocs/sw6/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/MiddlewareAwareTrait.php(70): call_user_func(Object(Slim\DeferredCallable), Object(Slim\Http\Request), Object(Slim\Http\Response), Object(Slim\App))
#23 /opt/lampp/htdocs/sw6/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/MiddlewareAwareTrait.php(117): Slim\App->Slim\{closure}(Object(Slim\Http\Request), Object(Slim\Http\Response))
#24 /opt/lampp/htdocs/sw6/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/App.php(392): Slim\App->callMiddlewareStack(Object(Slim\Http\Request), Object(Slim\Http\Response))
#25 /opt/lampp/htdocs/sw6/vendor/shopware/recovery/Common/vendor/slim/slim/Slim/App.php(297): Slim\App->process(Object(Slim\Http\Request), Object(Slim\Http\Response))
#26 /opt/lampp/htdocs/sw6/vendor/shopware/recovery/Install/index.php(51): Slim\App->run()
#27 /opt/lampp/htdocs/sw6/public/recovery/install/index.php(6): require_once('/opt/lampp/htdo...')
#28 {main}
Hast du das Xampp Controll Panel (und hierbei Mysql) gestartet?
Hi, danke für deine Antwort.
Ja, es ist alles gestartet.
Es wird auch zunächst in die Datenbank geschrieben, jedoch dann direkt abgebrochen.
