Bitte löschen!! Falsches Forum… Hallo, ich bekomme immer wieder folgende Error-Meldung: exception ‘Zend_Session_Exception’ with message ‘The session has already been started. The session id must be set first.’ in /var/www/web139447/html/wasd2/engine/Library/Zend/Session.php:709 Stack trace: #0 /var/www/web139447/html/wasd2/engine/Library/Zend/Session.php(421): Zend_Session::setId(‘da602f0b162fccb…’) #1 /var/www/web139447/html/wasd2/engine/Library/Zend/Session/Namespace.php(143): Zend_Session::start(true) #2 /var/www/web139447/html/wasd2/engine/Shopware/Components/DependencyInjection/Bridge/Session.php(81): Zend_Session_Namespace->__construct(‘Shopware’) #3 /var/www/web139447/html/wasd2/cache/proxies/Shopware201409241139ProductionProjectContainer.php(275): Shopware\Components\DependencyInjection\Bridge\Session->factory(Object(Shopware201409241139ProductionProjectContainer)) #4 /var/www/web139447/html/wasd2/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Container.php(312): Shopware201409241139ProductionProjectContainer->getSessionService() #5 /var/www/web139447/html/wasd2/engine/Shopware/Components/DependencyInjection/Container.php(253): Symfony\Component\DependencyInjection\Container->get(‘session’) #6 /var/www/web139447/html/wasd2/engine/Shopware/Components/DependencyInjection/Container.php(188): Shopware\Components\DependencyInjection\Container->load(‘session’) #7 /var/www/web139447/html/wasd2/engine/Shopware/Bootstrap.php(149): Shopware\Components\DependencyInjection\Container->get(‘Session’) #8 /var/www/web139447/html/wasd2/engine/Shopware/Application.php(196): Shopware_Bootstrap->getResource(‘Session’) #9 /var/www/web139447/html/wasd2/engine/Shopware/Plugins/Default/Core/Router/Bootstrap.php(342): Shopware->Session() #10 /var/www/web139447/html/wasd2/engine/Shopware/Plugins/Default/Core/Router/Bootstrap.php(230): Shopware_Plugins_Core_Router_Bootstrap->upgradeShop(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp)) #11 /var/www/web139447/html/wasd2/engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Core_Router_Bootstrap->onRouteShutdown(Object(Enlight_Controller_EventArgs)) #12 /var/www/web139447/html/wasd2/engine/Library/Enlight/Event/EventManager.php(211): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_EventArgs)) #13 /var/www/web139447/html/wasd2/engine/Library/Enlight/Controller/Front.php(190): Enlight_Event_EventManager->notify(‘Enlight_Control…’, Object(Enlight_Controller_EventArgs)) #14 /var/www/web139447/html/wasd2/engine/Shopware/Kernel.php(141): Enlight_Controller_Front->dispatch() #15 /var/www/web139447/html/wasd2/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(472): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #16 /var/www/web139447/html/wasd2/engine/Shopware/Components/HttpCache/AppCache.php(256): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #17 /var/www/web139447/html/wasd2/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(429): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true) #18 /var/www/web139447/html/wasd2/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(329): Symfony\Component\HttpKernel\HttpCache\HttpCache->fetch(Object(Symfony\Component\HttpFoundation\Request), true) #19 /var/www/web139447/html/wasd2/engine/Shopware/Components/HttpCache/AppCache.php(178): Symfony\Component\HttpKernel\HttpCache\HttpCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #20 /var/www/web139447/html/wasd2/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/HttpCache/HttpCache.php(193): Shopware\Components\HttpCache\AppCache->lookup(Object(Symfony\Component\HttpFoundation\Request), true) #21 /var/www/web139447/html/wasd2/engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #22 /var/www/web139447/html/wasd2/shopware.php(109): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request)) #23 {main} 2015-03-28T17:14:14.870037+0100 core { “uri”: “/”, “method”: “GET”, “query”: , “post”: } No session data available 1 Hauptshop Deutsch Wie ich in diesem Beitrag festgestellt habe, ist es der Baiduspider. Ich habe auch den letzten code aus diesem Beitrag in meine htaccess-Dateie hinzugefügt. Doch leider bekomme ich die Fehlermeldungen immer noch. Und wenn ich ins log schaue, ist es wieder der Baiduspider. Wie kann ich den denn aussperren? Danke und lg Nadja
