Do I need separate plugin license for each subshop?
I have following single shopware setup and want to use a purchse licnese plugin
Main Shop:
  1. www.myswshop.com
SubShops
  1. www.myswshop.fr
  2. www.myswshop.tr
  3. www.myswshop.de
Do I need 4 licneses, one for main shop and 3 for each subshops, or one license will work for all?
Your „main shop“ is your license domain. If you only have multiple subshops with different domains but you are using ONE shopware instance, you only need to buy a license once.
Kind regards
https://www.digitvision.de
Kind regards
Thank you very much
