Hello.
I was following the video: https://academy.shopware.com/courses/take/shopware-6-developer-training-english/lessons/9225170-data-storefront
When I try to access the website the following error appears:
{„errors“:[{„code“:„0“,„status“:„500“,„title“:„Internal Server Error“,„detail“:„Class \DemoDataController does not exist in /Users/alphabetus/Documents/repos/shopware01/custom/plugins/SwagShopFinder/src/Core/Api/DemoDataController.php (which is being imported from \u0022/Users/alphabetus/Documents/repos/shopware01/custom/plugins/SwagShopFinder/src/Resources/config/routes.xml\u0022). Make sure annotations are installed and enabled.“}]}
I’m stuck for a while trying to understand what is wrong.
The video never shows the full code that the guy is using only references.
Probably some imports are missing
DemoDataController.php goes as follows:
countryRepository = $countryRepository;
$this->shopFinderRepository = $shopFinderRepository;
* @Route("/api/v{version}/_action/swag-shop-finder/generate", name="api.custom.swag_shop_finder.generate", methods={"POST"})
* @param Context $context
* @return Response
* @throws CountryNotFoundException
* @throws InconsistentCriteriaIdsException
public function generate(Context $context): Response
$faker = Factory::create();
$country = $this->getActiveCountry($context);
$data = [];
for($i = 0; $i < 50; $i++){
$data[] = [
'id' => Uuid::randomHex(),
'active' => true,
'name' => $faker->name,
'street' => $faker->streetAddress,
'postcode' => $faker->postcode,
'city' => $faker->city,
'countryId' => $country->getId()
$this->shopFinderRepository->create($data, $context);
return new Response('', Response::HTTP_NO_CONTENT);
* @return CountryEntity
* @throws InconsistentCriteriaIdsException;
private function getActiveCountry(Context $context): CountryEntity
$criteria = new Criteria();
$criteria->addFilter(new EqualsFilter('active', '1'));
$criteria->setLimit(1);
$country = $this->countryRepository->search($criteria, $context)->getEntities()->first();
if ($country === null) {
throw new CountryNotFoundException('');
return $country;
Hello,
you use the wrong imports.
Here is my working DemoDataController
* return Response
public function generate(Context $context): Response {
$data = [];
for ($i = 0; $i < 50; $i++) {
$data[] = [
'active' => true,
'postCode' => $faker->postcode,
'countryId' => $country->getId(),
private function getActiveCountry(Context $context): CountryEntity {
if($country === null) {
return $country;
Hi for me helped adding the namespace to my controller. Obviously on training course there is no namespace, and it doesn’t work. Also i had to add created_ad and updated_at to my migration code.
my DemoDataController code is
<?php declare(strict_types=1);
use Faker\Factory;
use Shopware\Core\Framework\Context;
use Shopware\Core\Framework\DataAbstractionLayer\Exception\InconsistentCriteriaIdsException;
use Shopware\Core\Framework\DataAbstractionLayer\Search\Criteria;
use Shopware\Core\Framework\DataAbstractionLayer\Search\Filter\EqualsFilter;
use Shopware\Core\Framework\Uuid\Uuid;
use Shopware\Core\System\Country\CountryEntity;
use Shopware\Core\System\Country\Exception\CountryNotFoundException;
use Symfony\Bundle\FrameworkBundle\Controller\AbstractController;
use Shopware\Core\Framework\Routing\Annotation\RouteScope;
use Symfony\Component\Routing\Annotation\Route;
use Symfony\Component\HttpFoundation\Response;
* @RouteScope(scopes={"api"})
class DemoDataController extends AbstractController
* @var EntityRepositoryInterface
private $countryRepository;
private $shopFinderRepository;
public function __construct(
EntityRepositoryInterface $countryRepository, EntityRepositoryInterface $shopFinderRepository){
$this->countryRepository = $countryRepository;
* @return Response
$data = [];
for($i=0; $i<=25; $i++){
$data[] = [
'active' => true,
'postal_code' => $faker->postcode,
return new Response("", Response::HTTP_NO_CONTENT);
$criteria = New Criteria();
$result = $this->countryRepository->search($criteria, $context)->getEntities->first();
if($result===null){
throw new CountryNotFoundException();
return $result;
I got error
"errors": [
"code": "0",
"status": "500",
"title": "Internal Server Error",
"detail": "The controller for URI \"/api/v2/_action/swag-shop-finder/generate\" is not callable: Controller \"DemoDataController\" does neither exist as service nor as class."
can you help??@rahmspinat
I had the same problem and i solved it by checking my ide (using phpstorm).
In my case there were some imports missing. In the very first i forgot the namespace definition in my DemoDataController.php and this did lead to the exact same error (DemoDataController class is missing).
Later on i had to add some use statements in addition and phpstorm helped me with this quite comfortable.
