Decimal Processing
Hi everyone, I have adjusted the backend theme so that I can enter more than 2 decimal places when editing an article.
This also works and is also stored correctly in the database.
Now I have the problem that in the fast editing the value is still rounded, although I have already increased decimal precision in all places to 4 which I have found by searching and toFixed is also on 4.
Does anyone have an idea how I can adapt the fast editing so that the price is not rounded to 2 decimal places? I think the problem lies with Extjs as I leave the field, the price is rounded to 2 decimal places. https://dltutuapp.com/tutuapp-download https://showbox.run/ https://kodi.software/
you must change it hier :
https://github.com/shopware/shopware/blob/5.6/engine/Shopware/Components/MultiEdit/Resource/Product/DqlHelper.php#L460
offcours you can use the filter event hier:
https://github.com/shopware/shopware/blob/5.6/engine/Shopware/Components/MultiEdit/Resource/Product/DqlHelper.php#L518
VG,
Tel.: +49 755 - 183 990 00 | Email: info@enbit.de | Web: http://enbit.de/
I started learning processing since a short time ago and I came across a problem; When deviding 199.999 by 200 I want to outcome to be with 2 decimals (so the outcome should be 1 rounded of). Without formatting the outcome is 0.999995.
Code for formatting to String with 2 decimal:
float money = 199.999;
int munten = 200;
String calc1 = nf(money/munten,0,2);
println(calc1);
float calc2 = float(calc1);
println(calc2);
[get-vidmate.com](https://get-vidmate.com) [instasave.onl](https://instasave.onl)float money = 199.999;
int munten = 200;
println(calc1);
println(calc2);
Thanks, i was very confused about it.. .
