I am developing a plugin for Shopware, and it should add a custom module under the Catalogues section in the admin menu. However, the module is not appearing in the admin panel.
Here is the relevant part of my code:
import deDE from ‚./snippet/de-DE‘;
import enGB from ‚./snippet/en-GB‘;
Shopware.Component.register(‚webeface-test‘, () => import(‚…/page/webeface-test‘));
Shopware.Module.register(‚webeface-product-wishes‘, {
type: ‚plugin‘,
title: ‚webeface.administration.menuItem‘,
description: ‚webeface.administration.description‘,
color: ‚#ff3d58‘,
icon: ‚default-shopping-paper-bag-product‘,
snippets: {
'de-DE': deDE,
'en-GB': enGB
routes: {
test: {
component: 'webeface-test',
path: 'test'
navigation: [{
label: 'webeface.administration.navItem',
color: '#ff3d58',
path: 'webeface.product.wishes.test',
icon: 'default-shopping-paper-bag-product',
parent: 'sw-catalogue',
position: 100
What I’ve Checked:
- Routes: The routes are correctly set and reachable. I’ve confirmed that there are no typos in the routes or paths, and the component (
webeface-test) is correctly registered. - Snippets: The snippet files (
de-DEanden-GB) are configured properly, and the labelswebeface.administration.menuItemandwebeface.administration.navItemare defined in the snippet files. - Cache Clearing: I’ve run
./bin/console cache:clearand./bin/console cache:warmupmultiple times. I’ve also cleared the browser cache and tested in incognito mode. - Permissions: The admin user I’m testing with has full permissions, so this shouldn’t be a permission issue.
