Custom Image measure and dimension selection for product
Hi everyone,
I’m new to Shopware and need some help. I want to create a page in Shopware 6 where users can choose a product and enter its measurements and dimensions. When they add this customized product to the cart, only the selected part gets added.
The products I’m working with are usually fabrics with specific patterns or designs. Users should be able to pick a pattern from any starting point.
If you know of any themes or plugins in Shopware 6 that can handle this, I’d really appreciate your suggestions. My client has also given me an example image from another Shopware site that has similar functionality.
For reference, here’s a link to a WordPress WooCommerce plugin with similar features (just to ): Custom Made Photo Wallpaper WooCommerce Plugin just to illustrate the functionality I’m looking for. I’m looking for something like this for Shopware 6.
Thanks for any help or tips you can provide!
Hast du ein Plug n gefunden, mit dem das geht? Würde mir auch weiterhelfen.
