Creating a function after payment is successfully done
I want to create some function that when payment transition is successfully done. Is there a method for that or how can i handle that transition ?
NOTE : I’m using Mollie plugin
Maybe Mollie has a Webhook, not sure about that.
Or create your own plugin, subscribe to the Event and execute your code.
Actually, i am trying to create my own plugin for this situation but the bad part is every method i’ve tried didn’t fix my problem yet.
All i’m asking is state_enter.order_transaction.state.paid is this one the correct method for to handle „paid“ statement ?
use Psr\Log\LoggerInterface;
use Shopware\Core\Checkout\Order\OrderEntity;
use Shopware\Core\Checkout\Order\Aggregate\OrderLineItem\OrderLineItemEntity;
use Shopware\Core\Checkout\Order\Aggregate\OrderTransaction\OrderTransactionEntity;
use Shopware\Core\Checkout\Payment\PaymentState;
use Shopware\Core\Framework\DataAbstractionLayer\EntityRepository;
use Shopware\Core\Framework\DataAbstractionLayer\Search\Criteria;
use Shopware\Core\System\StateMachine\Event\StateMachineTransitionEvent;
use Symfony\Component\EventDispatcher\EventSubscriberInterface;
class OrderSubscriber implements EventSubscriberInterface
    private EntityRepository $orderTransactionRepository;
    private EntityRepository $orderRepository;
    private LoggerInterface $logger;
    private string $partnerToken;
    private string $userToken;
    public function __construct(
        EntityRepository $orderTransactionRepository,
        EntityRepository $orderRepository,
        LoggerInterface $logger,
        string $partnerToken,
        string $userToken
        $this->orderTransactionRepository = $orderTransactionRepository;
        $this->orderRepository = $orderRepository;
        $this->logger = $logger;
        $this->partnerToken = $partnerToken;
        $this->userToken = $userToken;
    public static function getSubscribedEvents(): array
        return [
            'state_enter.order_transaction.state.paid' => 'onOrderPaid',
    public function onOrderPaid(StateMachineTransitionEvent $event): void
        $transactionId = $event->getEntityId();
        $transaction = $this->orderTransactionRepository->search(
            (new Criteria([$transactionId]))
                ->addAssociation('order.lineItems')
                ->addAssociation('order.billingAddress.country')
                ->addAssociation('paymentMethod'),
            $event->getContext()
        )->first();
        if (!$transaction instanceof OrderTransactionEntity) {
            return;
        $order = $transaction->getOrder();
        if (!$order instanceof OrderEntity) {
            return;
check the file vendor/shopware/core/Checkout/Order/OrderEvents.php here you can find all events which are triggered by shopware.
you could also create a custom flow event and configure it in flow builder
