Broken Links after updating from 4.3.7 to 5.x.x - no subfolder in the url, though in the base_path
The shop exists in a staging environment and works well until beeing updated to Shopware 5.x.x
After beeing updated all links miss the subfolder name in its urls, though it remains beeing set in the base_path field of s_core_shops table.
Before the update there was an other Theme beeing active, now it is deleted. But I doubt it might be important.
If you use a virtual url like /en or /de the base_path is also required in the virtual url - /test/de or /test/en.
Heh, nice it works : ). But what you call virtual url' is in s_core_shops’ called base_url' and in fact the /test’ part is not virtual.
