Bin/console theme:compile error
I have error when running bin/console theme:compile
message: „User Deprecated: Since shopware/core : Class Shopware\Storefront\Event\ThemeCompilerEnrichScssVariablesEvent is deprecated. Use Shopware\Storefront\Theme\Event\ThemeCompilerEnrichScssVariablesEvent instead.“
Same here since the new update. But it doesn’t seem to have negative effects. It still compiles my files as usual…
These are Deprecated warnings, no errors.
Guess Shopware will/need to change the code in the referred files.
AlexBS, Max_Shop
Thank you, I was unable to pick my theme inside admin panel, and I thouht that this was because of compiling problems. Now I reinstall and rebuild shopware. Console is the same but now I`m able to pick my theme)
