Backend Fehler
Leider funktioniert mein Backend nur noch eingeschränkt. Es ist kein User-bezogenes Problem.
unable to create directory /var/www/vhosts/woodq.de/httpdocs/var/cache/production_202008121209/templates/backend_de_DE_a76fc/b3/59/6e in engine/Library/Smarty/sysplugins/smarty_internal_write_file.php on line 54
Stack trace:
#0 engine/Library/Smarty/sysplugins/smarty\_internal\_template.php(201): Smarty\_Internal\_Write\_File::writeFile('/var/www/vhosts...', '\<?php /\* Smarty...', Object(Enlight\_Template\_Manager))
 #1 engine/Library/Smarty/sysplugins/smarty\_internal\_templatebase.php(155): Smarty\_Internal\_Template-\>compileTemplateSource()
 #2 engine/Library/Enlight/View/Default.php(295): Smarty\_Internal\_TemplateBase-\>fetch()
 #3 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(212): Enlight\_View\_Default-\>render(Object(Enlight\_Template\_Default))
 #4 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(238): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>renderTemplate(Object(Enlight\_Template\_Default))
 #5 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(132): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>render()
 #6 engine/Library/Enlight/Event/Handler/Default.php(87): Enlight\_Controller\_Plugins\_ViewRenderer\_Bootstrap-\>onPostDispatch(Object(Enlight\_Controller\_ActionEventArgs))
 #7 engine/Library/Enlight/Event/EventManager.php(214): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs))
 #8 engine/Library/Enlight/Controller/Action.php(233): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs))
 #9 engine/Library/Enlight/Controller/Dispatcher/Default.php(478): Enlight\_Controller\_Action-\>dispatch('loadAction')
 #10 engine/Library/Enlight/Controller/Front.php(228): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp))
 #11 engine/Shopware/Kernel.php(188): Enlight\_Controller\_Front-\>dispatch()
 #12 vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #13 vendor/symfony/http-kernel/HttpCache/HttpCache.php(453): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
 #14 engine/Shopware/Components/HttpCache/AppCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
 #15 vendor/symfony/http-kernel/HttpCache/HttpCache.php(238): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true)
 #16 engine/Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true)
 #17 shopware.php(122): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request))
 #18 {main}
Hat jemand einen Lösungsvorschlag?
Liebe Grüße,
Niklas
Speicherplatz voll ?
@SCOOPEX schrieb:
Wir haben erst 1,4 GB von 5 GB belegt, also dürfte es nicht am allgemeinen Speicherplatz liegen :slight_smile:
Beste Grüße
prüfe ggfs. auch mal die Statistiken im Controlpanel. Möglich, dass der Speicherplatz auch durch Logfiles, emails etc. aufgebraucht ist.
Lt. Fehlermeldung kann jedenfalls das Cache Verzeichnis nicht korrekt erstellt werden.
Inodes alle belegt? Mal leere Ordner löschen: https://forum.shopware.com/discussion/56125/leere-ordner-loeschen#latest
@SCOOPEX schrieb:
Es lag Tatsächlich am Cache Verzeichnis. Die Lösung war ganz simpel, ein unter var/cache den productions Ordner löschen :smiley:
Beste Grüße
Wenn der Tarif nur 5 GB hat und nur noch so wenig frei sind, hast du vielleicht auch langsame Hardware bzw. andere sehr niedrige Limits bei dem SharedHoster?
Also ich würde (ich weiß ja nicht wieviel der Shop mittlerweile abwirft) den Tarif ggf. vergrößern.
