seit einem Update von 5.2.21 auf 5.2.27 bekomme ich folgende Fehler bei der AJAX Validierung der Passwörter und E-Mail Adresse bei Neuanmeldungen:
Exception: DateTime::__construct(): Failed to parse time string (NULL) at position 0 (N): The timezone could not be found in the database in /var/www/clients/client1/web1/web/var/cache/production_201707131430/doctrine/attributes/Customer.php:153 Stack trace:
#0 /var/www/clients/client1/web1/web/var/cache/production_201707131430/doctrine/attributes/Customer.php(153): DateTime->__construct(‚NULL‘)
#1 /vendor/symfony/form/Extension/Core/Type/FormType.php(139): Shopware\Models\Attribute\Customer->__construct()
#2 /vendor/symfony/form/Form.php(607): Symfony\Component\Form\Extension\Core\Type\FormType->Symfony\Component\Form\Extension\Core\Type{closure}(Object(Symfony\Component\Form\Form), NULL)
#3 /vendor/symfony/form/Form.php(567): Symfony\Component\Form\Form->submit(Array, true)
#4 /engine/Shopware/Controllers/Frontend/Register.php(418): Symfony\Component\Form\Form->submit(Array)
#5 /engine/Shopware/Controllers/Frontend/Register.php(111): Shopware_Controllers_Frontend_Register->createCustomerForm(Array)
#6 /var/www/clients/client1/web1/web/var/cache/production_201707131430/proxies/ShopwareControllersFrontendRegisterProxy.php(6): Shopware_Controllers_Frontend_Register->saveRegisterAction()
#7 /engine/Library/Enlight/Hook/HookManager.php(186): Shopware_Proxies_ShopwareControllersFrontendRegisterProxy->executeParent(‚saveRegisterAct…‘, Array)
#8 /var/www/clients/client1/web1/web/var/cache/production_201707131430/proxies/ShopwareControllersFrontendRegisterProxy.php(17): Enlight_Hook_HookManager->executeHooks(Object(Shopware_Proxies_ShopwareControllersFrontendRegisterProxy), ‚saveRegisterAct…‘, Object(Enlight_Hook_HookArgs))
#9 /engine/Library/Enlight/Controller/Action.php(159): Shopware_Proxies_ShopwareControllersFrontendRegisterProxy->saveRegisterAction()
#10 /engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight_Controller_Action->dispatch(‚saveRegisterAct…‘)
#11 /engine/Library/Enlight/Controller/Front.php(223): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#12 /engine/Shopware/Kernel.php(182): Enlight_Controller_Front->dispatch()
#13 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(491): Shopware\Kernel->handle(Object(Enlight_Controller_Request_RequestHttp), 1, true)
#14 /engine/Shopware/Components/HttpCache/AppCache.php(266): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#15 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#16 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(275): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#17 /engine/Shopware/Components/HttpCache/AppCache.php(141): Symfony\Component\HttpKernel\HttpCache\HttpCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true)
#18 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(206): Shopware\Components\HttpCache\AppCache->invalidate(Object(Symfony\Component\HttpFoundation\Request), true)
#19 /engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#20 /var/www/clients/client1/web1/web/shopware.php(117): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#21 {main}
Demzufolge kann sich leider kein neuer User aktuell anmelden
Weiß jemand Hilfe dazu?
