Hello, is there a way I can change the Advanced Menu setting, that menu won´t show its content on hover but on the click?
Depends if the hover-effect is set in a tpl-file, in that case you could simply overwrite it with the onclick event.
Though, I think shopware creates the navigation on-the-fly inside a javascript file (just a guess!) so you might have to change that one instead…
I think there was a way to remove and add such events by jquery which is included in shopware by default.
Might be easier to create a js-file that removes the hover event with an on-click one inside a loop over the navigation.
I’d suggest you clone your shop to a test system, grab the developers guide and fiddle around a little.
Even if you screw the shop up, there won’t be any harm since it’s just a clone and if things turn too ugly you can always re-copy the shop over it
