Admin Panel doesn't display plugin from shopware
i am new to shopware . My admin panel doesn’t show sytem info , plugins from shopware and not able to install plugin using upload. it just stays blank
Hello,
which version do you use? Is it a github installation?
Moritz
I use shopware 5.2.3 , and installed using softaculous . If you need login details to check i can send you a personal message
Hi
I tried installing version 5.1.6 in installation database is created at teh step configration i am getting an error
Slim Application Error
Type:  ErrorException
Code:  8
Message:  Undefined index: c_config_admin_language
File:  /home/latestthemes/public_html/shopware/recovery/install/src/app.php
Line:  378
Trace
#0 /home/latestthemes/public_html/shopware/recovery/install/src/app.php(378): Slim\Slim::handleErrors(8, ‘Undefined index…’, ‘/home/latestthe…’, 378, Array)#1 [internal function]: {closure}()#2 /home/latestthemes/public_html/shopware/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array)#3 /home/latestthemes/public_html/shopware/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch()#4 /home/latestthemes/public_html/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()#5 /home/latestthemes/public_html/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()#6 /home/latestthemes/public_html/shopware/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()#7 /home/latestthemes/public_html/shopware/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call()#8 /home/latestthemes/public_html/shopware/recovery/install/index.php(74): Slim\Slim->run()
#9 {main}
Kindly help me on this .
