Wenn ich Kunden im Backend anrufe bekommen ich 0 communication failure…
Im Log file steht :
Enlight_Controller_Exception: Permission denied in /engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php:254 Stack trace:
#0 /engine/Shopware/Plugins/Default/Backend/Auth/Bootstrap.php(207): Shopware_Plugins_Backend_Auth_Bootstrap->checkAuth()
#1 /engine/Library/Enlight/Event/Handler/Plugin.php(149): Shopware_Plugins_Backend_Auth_Bootstrap->onPreDispatchBackend(Object(Enlight_Controller_ActionEventArgs))
#2 /engine/Library/Enlight/Event/EventManager.php(220): Enlight_Event_Handler_Plugin->execute(Object(Enlight_Controller_ActionEventArgs))
#3 /engine/Library/Enlight/Controller/Action.php(171): Enlight_Event_EventManager->notify(‚Enlight_Control…‘, Object(Enlight_Controller_ActionEventArgs))
#4 /engine/Library/Enlight/Controller/Dispatcher/Default.php(563): Enlight_Controller_Action->dispatch(‚createLogAction‘)
#5 /engine/Library/Enlight/Controller/Front.php(222): Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))
#6 /engine/Shopware/Kernel.php(202): Enlight_Controller_Front->dispatch()
#7 /vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel->handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#8 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(448): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle(Object(Shopware\Kernel), Object(Symfony\Component\HttpFoundation\Request), 1, true)
#9 /engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#10 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(238): Shopware\Components\HttpCache\AppCache->forward(Object(Symfony\Component\HttpFoundation\Request), true)
#11 /engine/Shopware/Components/HttpCache/AppCache.php(105): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass(Object(Symfony\Component\HttpFoundation\Request), true)
#12 /var/www/shopware/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle(Object(Symfony\Component\HttpFoundation\Request))
#13 {main}
hat jemand eine Idee? Problem ist nur auf test Instanz auf Lokal funktioniert gut.
Danke.
