Import-Export is not Completed and stuck in process method
Hello EveryOne,
I am facing the import-export issue in shopware 6 backend. I am facing that the data or csv I have put into export or import after the process method it will not generate the records and process method executes infinitely.
@smit Hi, have you found a solution for this? We are suddenly experiencing this too. The odd thing is that it sometimes works and sometimes doesn’t. There are no error messages anywhere.
@patrickLeenders No. I am still facing this issue.
