wenn ich auf die Swagger Seite (http://shopware.none/api/v3/_info/swagger.html | ist in hosts eingetragen und verweist auf 127.0.0.1) von Shopware 6 im DEV-MODE und gelöschtem Cache gehe erscheint der folgende Fehler. Wie kann ich ihn beheben?
{"errors":[{"code":"0","status":"404","title":"Not Found","detail":"No route found for \u0022GET \/api\/v3\/_info\/swagger.html\u0022","meta":{"trace":[{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/event-dispatcher\/Debug\/WrappedListener.php","line":117,"function":"onKernelRequest","class":"Symfony\\Component\\HttpKernel\\EventListener\\RouterListener","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/event-dispatcher\/EventDispatcher.php","line":230,"function":"__invoke","class":"Symfony\\Component\\EventDispatcher\\Debug\\WrappedListener","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/event-dispatcher\/EventDispatcher.php","line":59,"function":"callListeners","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/shopware\/core\/Framework\/Webhook\/WebhookDispatcher.php","line":81,"function":"dispatch","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/shopware\/core\/Framework\/Event\/BusinessEventDispatcher.php","line":46,"function":"dispatch","class":"Shopware\\Core\\Framework\\Webhook\\WebhookDispatcher","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/shopware\/core\/Framework\/Event\/NestedEventDispatcher.php","line":32,"function":"dispatch","class":"Shopware\\Core\\Framework\\Event\\BusinessEventDispatcher","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/event-dispatcher\/Debug\/TraceableEventDispatcher.php","line":151,"function":"dispatch","class":"Shopware\\Core\\Framework\\Event\\NestedEventDispatcher","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/HttpKernel.php","line":133,"function":"dispatch","class":"Symfony\\Component\\EventDispatcher\\Debug\\TraceableEventDispatcher","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/HttpKernel.php","line":79,"function":"handleRaw","class":"Symfony\\Component\\HttpKernel\\HttpKernel","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/Kernel.php","line":195,"function":"handle","class":"Symfony\\Component\\HttpKernel\\HttpKernel","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/HttpCache\/SubRequestHandler.php","line":85,"function":"handle","class":"Symfony\\Component\\HttpKernel\\Kernel","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/HttpCache\/HttpCache.php","line":477,"function":"handle","class":"Symfony\\Component\\HttpKernel\\HttpCache\\SubRequestHandler","type":"::"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/HttpCache\/HttpCache.php","line":450,"function":"forward","class":"Symfony\\Component\\HttpKernel\\HttpCache\\HttpCache","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/HttpCache\/HttpCache.php","line":344,"function":"fetch","class":"Symfony\\Component\\HttpKernel\\HttpCache\\HttpCache","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/HttpCache\/HttpCache.php","line":222,"function":"lookup","class":"Symfony\\Component\\HttpKernel\\HttpCache\\HttpCache","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/shopware\/core\/HttpKernel.php","line":163,"function":"handle","class":"Symfony\\Component\\HttpKernel\\HttpCache\\HttpCache","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/shopware\/core\/HttpKernel.php","line":80,"function":"doHandle","class":"Shopware\\Core\\HttpKernel","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/public\/index.php","line":77,"function":"handle","class":"Shopware\\Core\\HttpKernel","type":"-\u003E"}],"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/EventListener\/RouterListener.php","line":136,"previous":[{"code":"0","status":"500","title":"Internal Server Error","detail":"No routes found for \u0022\/api\/v3\/_info\/swagger.html\/\u0022.","meta":{"trace":[{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/routing\/Matcher\/UrlMatcher.php","line":106,"function":"match","class":"Symfony\\Component\\Routing\\Matcher\\CompiledUrlMatcher","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/routing\/Router.php","line":257,"function":"matchRequest","class":"Symfony\\Component\\Routing\\Matcher\\UrlMatcher","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/shopware\/storefront\/Framework\/Routing\/Router.php","line":51,"function":"matchRequest","class":"Symfony\\Component\\Routing\\Router","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/EventListener\/RouterListener.php","line":112,"function":"matchRequest","class":"Shopware\\Storefront\\Framework\\Routing\\Router","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/event-dispatcher\/Debug\/WrappedListener.php","line":117,"function":"onKernelRequest","class":"Symfony\\Component\\HttpKernel\\EventListener\\RouterListener","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/event-dispatcher\/EventDispatcher.php","line":230,"function":"__invoke","class":"Symfony\\Component\\EventDispatcher\\Debug\\WrappedListener","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/event-dispatcher\/EventDispatcher.php","line":59,"function":"callListeners","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/shopware\/core\/Framework\/Webhook\/WebhookDispatcher.php","line":81,"function":"dispatch","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/shopware\/core\/Framework\/Event\/BusinessEventDispatcher.php","line":46,"function":"dispatch","class":"Shopware\\Core\\Framework\\Webhook\\WebhookDispatcher","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/shopware\/core\/Framework\/Event\/NestedEventDispatcher.php","line":32,"function":"dispatch","class":"Shopware\\Core\\Framework\\Event\\BusinessEventDispatcher","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/event-dispatcher\/Debug\/TraceableEventDispatcher.php","line":151,"function":"dispatch","class":"Shopware\\Core\\Framework\\Event\\NestedEventDispatcher","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/HttpKernel.php","line":133,"function":"dispatch","class":"Symfony\\Component\\EventDispatcher\\Debug\\TraceableEventDispatcher","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/HttpKernel.php","line":79,"function":"handleRaw","class":"Symfony\\Component\\HttpKernel\\HttpKernel","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/Kernel.php","line":195,"function":"handle","class":"Symfony\\Component\\HttpKernel\\HttpKernel","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/HttpCache\/SubRequestHandler.php","line":85,"function":"handle","class":"Symfony\\Component\\HttpKernel\\Kernel","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/HttpCache\/HttpCache.php","line":477,"function":"handle","class":"Symfony\\Component\\HttpKernel\\HttpCache\\SubRequestHandler","type":"::"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/HttpCache\/HttpCache.php","line":450,"function":"forward","class":"Symfony\\Component\\HttpKernel\\HttpCache\\HttpCache","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/HttpCache\/HttpCache.php","line":344,"function":"fetch","class":"Symfony\\Component\\HttpKernel\\HttpCache\\HttpCache","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/http-kernel\/HttpCache\/HttpCache.php","line":222,"function":"lookup","class":"Symfony\\Component\\HttpKernel\\HttpCache\\HttpCache","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/shopware\/core\/HttpKernel.php","line":163,"function":"handle","class":"Symfony\\Component\\HttpKernel\\HttpCache\\HttpCache","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/vendor\/shopware\/core\/HttpKernel.php","line":80,"function":"doHandle","class":"Shopware\\Core\\HttpKernel","type":"-\u003E"},{"file":"\/var\/www\/html\/sw6\/public\/index.php","line":77,"function":"handle","class":"Shopware\\Core\\HttpKernel","type":"-\u003E"}],"file":"\/var\/www\/html\/sw6\/vendor\/symfony\/routing\/Matcher\/Dumper\/CompiledUrlMatcherTrait.php","line":70}}]}}]}
Ich freue mich über jede Hilfe.
