Hi, I’ve created a custom plugin SwagStartup in Shopware, and it works by calling an url like “shopware.project/myDemo”.
Then I tried to define/use event subscriber in this plugin, following is the code:
namespace SwagStartup\Subscriber;
use Enlight\Event\SubscriberInterface;
class RoutingSubscriber implements SubscriberInterface
public static function getSubscribedEvents(){
return ['Enlight_Controller_Action_PreDispatch' => 'onPreDispatch'];
public function onPreDispatch(Enlight_Event_EventArgs $args){
die('here!');
And the XML file: Resources/services.xml:
When I called the url like before, I expected to see the output from the die() function, cause I thought the event Enlight_Controller_Action_PreDispatch should have been caught by the subscriber and the funciton onPreDispatch() should have been called - but it was not the case.
What’s wrong? Can someone tell me?
