Wir haben den Viision Adapter Deutsche Post in unserem Testsystem problemlos installiert und getestet. Nun sollte das auch im Livesystem passieren. Doch leider lässt sich das Plaugin nicht installieren. Die Warte-Grafik rennt und rennt und rennt.
Der Eintrag in der Tabelle s_core_plugins erfolgt, aber das ist alles. Im Log habe ich folgende Einträge:
[2019-02-08 14:27:46] pickware.INFO: Installation for plugin "ViisonGermanPost" requested. {"pluginName":"ViisonGermanPost","version":"1.9.0.55","username":"John Doe"} {"uid":"1b70b75"}
[2019-02-08 14:27:46] pickware.INFO: Plugin "ViisonGermanPost" is trying to acquire a lock to block other plugin setups for the next 300 seconds. {"pluginName":"ViisonGermanPost","version":"1.9.0.55","username":"John Doe"} {"uid":"1b70b75"}
[2019-02-08 14:27:46] pickware.ERROR:
Installation of plugin "ViisonGermanPost" failed with the following error:
"The installation or update of Plugin "Deutsche Post Adapter" is blocked because an update of the plugin "ViisonGermanPost" is currently running.
Please try again in 4 minutes at the earliest or when the update of the named plugin has been finished."
"versionNew":"1.9.0.55",
"user" :"John Doe",
"exception":{
"class" :"Shopware\\Plugins\\ViisonCommon\\Classes\\Exceptions\\InstallationException",
"message":"The installation or update of Plugin \"Deutsche Post Adapter\" is blocked because an update of the plugin \"ViisonGermanPost\" is currently running. Please try again in 4 minutes at the earliest or when the update of the named plugin has been finished.",
"file" :"/is/htdocs/wp13229909_2UPT9QUP9X/www/littlewonders_1/engine/Shopware/Plugins/Community/Backend/ViisonGermanPost/ViisonCommon/Classes/Exceptions/InstallationException.php",
"line" :79,
"code" :0,
"trace" :[
"#0 /is/htdocs/wp13229909_2UPT9QUP9X/www/littlewonders_1/engine/Shopware/Plugins/Community/Backend/ViisonDHL/ViisonCommon/PluginBootstrapV8.php(458):
Shopware\\Plugins\\ViisonCommon\\Classes\\Exceptions\\InstallationException::installationBlockedByActiveLock(Object(Shopware_Plugins_Backend_ViisonGermanPost_Bootstrap), 'ViisonGermanPos...', 186)",
"#1 /is/htdocs/wp13229909_2UPT9QUP9X/www/littlewonders_1/engine/Shopware/Plugins/Community/Backend/ViisonDHL/ViisonCommon/PluginBootstrapV10.php(40):
ViisonCommon_Plugin_BootstrapV8->executeSetupMethod('Installation', Object(Closure))",
"#2 /is/htdocs/wp13229909_2UPT9QUP9X/www/littlewonders_1/engine/Shopware/Components/Plugin/Namespace.php(251):
ViisonCommon_Plugin_BootstrapV10->install()",
"#3 /is/htdocs/wp13229909_2UPT9QUP9X/www/littlewonders_1/engine/Shopware/Bundle/PluginInstallerBundle/Service/LegacyPluginInstaller.php(99):
Shopware_Components_Plugin_Namespace->installPlugin(Object(Shopware_Plugins_Backend_ViisonGermanPost_Bootstrap))",
"#4 /is/htdocs/wp13229909_2UPT9QUP9X/www/littlewonders_1/engine/Shopware/Bundle/PluginInstallerBundle/Service/InstallerService.php(174):
Shopware\\Bundle\\PluginInstallerBundle\\Service\\LegacyPluginInstaller->installPlugin(Object(Shopware\\Models\\Plugin\\Plugin))",
"#5 /is/htdocs/wp13229909_2UPT9QUP9X/www/littlewonders_1/engine/Shopware/Plugins/Default/Backend/PluginManager/Controllers/Backend/PluginInstaller.php(66): Shopware\\Bundle\\PluginInstallerBundle\\Service\\InstallerService->installPlugin(Object(Shopware\\Models\\Plugin\\Plugin))",
"#6 /is/htdocs/wp13229909_2UPT9QUP9X/www/littlewonders_1/engine/Library/Enlight/Controller/Action.php(193):
Shopware_Controllers_Backend_PluginInstaller->installPluginAction()",
"#7 /is/htdocs/wp13229909_2UPT9QUP9X/www/littlewonders_1/engine/Library/Enlight/Controller/Dispatcher/Default.php(549):
Enlight_Controller_Action->dispatch('installPluginAc...')",
"#8 /is/htdocs/wp13229909_2UPT9QUP9X/www/littlewonders_1/engine/Library/Enlight/Controller/Front.php(222):
Enlight_Controller_Dispatcher_Default->dispatch(Object(Enlight_Controller_Request_RequestHttp), Object(Enlight_Controller_Response_ResponseHttp))",
"#9 /is/htdocs/wp13229909_2UPT9QUP9X/www/littlewonders_1/engine/Shopware/Kernel.php(202): Enlight_Controller_Front->dispatch()",
"#10 /is/htdocs/wp13229909_2UPT9QUP9X/www/littlewonders_1/vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102):
Shopware\\Kernel->handle(Object(Symfony\\Component\\HttpFoundation\\Request), 1, true)",
"#11 /is/htdocs/wp13229909_2UPT9QUP9X/www/littlewonders_1/vendor/symfony/http-kernel/HttpCache/HttpCache.php(448):
Symfony\\Component\\HttpKernel\\HttpCache\\SubRequestHandler::handle(Object(Shopware\\Kernel), Object(Symfony\\Component\\HttpFoundation\\Request), 1, true)",
"#12 /is/htdocs/wp13229909_2UPT9QUP9X/www/littlewonders_1/engine/Shopware/Components/HttpCache/AppCache.php(268):
Symfony\\Component\\HttpKernel\\HttpCache\\HttpCache->forward(Object(Symfony\\Component\\HttpFoundation\\Request), true, NULL)",
"#13 /is/htdocs/wp13229909_2UPT9QUP9X/www/littlewonders_1/vendor/symfony/http-kernel/HttpCache/HttpCache.php(238):
Shopware\\Components\\HttpCache\\AppCache->forward(Object(Symfony\\Component\\HttpFoundation\\Request), true)",
"#14 /is/htdocs/wp13229909_2UPT9QUP9X/www/littlewonders_1/engine/Shopware/Components/HttpCache/AppCache.php(105):
Symfony\\Component\\HttpKernel\\HttpCache\\HttpCache->pass(Object(Symfony\\Component\\HttpFoundation\\Request), true)",
"#15 /is/htdocs/wp13229909_2UPT9QUP9X/www/littlewonders_1/shopware.php(122):
Shopware\\Components\\HttpCache\\AppCache->handle(Object(Symfony\\Component\\HttpFoundation\\Request))",
"#16 {main}"
"previous":null
"uid":"1b70b75"
Hat vielleicht jemand einen Tipp für mich, wie ich weiterkomme?
