Die -Vergleichen-Funktion in meinem Shop (Artikeldetailansicht) funktioniert nicht, d.h. man klickt darauf, es passiert aber nichts ausser dass eine Fehlermeldung generiert wird.
Wo/Was müsste ich prüfen um das wieder zu korrigieren. Nachfolgend die Fehlermeldung:
Shopware\Components\CSRFTokenValidationException: The provided X-CSRF-Token for path "/compare/add\_article/articleID/3987" is invalid. Please go back, reload the page and try again. in /var/www/clients/client1/web4/web/engine/Shopware/Components/CSRFTokenValidator.php:155
Stack trace:
#0 /var/www/clients/client1/web4/web/engine/Library/Enlight/Event/Handler/Default.php(91): Shopware\Components\CSRFTokenValidator-\>checkFrontendTokenValidation(Object(Enlight\_Controller\_ActionEventArgs))
#1 /var/www/clients/client1/web4/web/engine/Library/Enlight/Event/EventManager.php(214): Enlight\_Event\_Handler\_Default-\>execute(Object(Enlight\_Controller\_ActionEventArgs))
#2 /var/www/clients/client1/web4/web/engine/Library/Enlight/Controller/Action.php(141): Enlight\_Event\_EventManager-\>notify('Enlight\_Control...', Object(Enlight\_Controller\_ActionEventArgs))
#3 /var/www/clients/client1/web4/web/engine/Library/Enlight/Controller/Dispatcher/Default.php(530): Enlight\_Controller\_Action-\>dispatch('addArticleActio...')
#4 /var/www/clients/client1/web4/web/engine/Library/Enlight/Controller/Front.php(223): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp))
#5 /var/www/clients/client1/web4/web/engine/Shopware/Kernel.php(184): Enlight\_Controller\_Front-\>dispatch()
#6 /var/www/clients/client1/web4/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(491): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#7 /var/www/clients/client1/web4/web/engine/Shopware/Components/HttpCache/AppCache.php(268): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL)
#8 /var/www/clients/client1/web4/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true)
#9 /var/www/clients/client1/web4/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(275): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true)
#10 /var/www/clients/client1/web4/web/engine/Shopware/Components/HttpCache/AppCache.php(143): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>invalidate(Object(Symfony\Component\HttpFoundation\Request), true)
#11 /var/www/clients/client1/web4/web/vendor/symfony/http-kernel/HttpCache/HttpCache.php(206): Shopware\Components\HttpCache\AppCache-\>invalidate(Object(Symfony\Component\HttpFoundation\Request), true)
#12 /var/www/clients/client1/web4/web/engine/Shopware/Components/HttpCache/AppCache.php(116): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true)
#13 /var/www/clients/client1/web4/web/shopware.php(118): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request))
#14 {main}
2018-02-26T09:01:35.498578+0100
core
"uri": "/compare/add\_article/articleID/3987",
"method": "POST",
"query": {
"module": "frontend",
"controller": "compare",
"action": "add\_article",
"articleID": "3987"
"post": []
