Ups! Ein Fehler ist aufgetreten! Bitte um Hilfe!
bekomme diese Fehlermeldung beim backend.
MfG
Afshin
Invalid compiled template for ‚backend/index/auth.tpl|backend/stripe_payment/index/header.tpl|backend/paypal_unified/menu_icon.tpl|backend/index/WCB/header.tpl‘ in engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php on line 174
Stack trace:
#0 engine/Library/Enlight/View/Default.php(295): Smarty_Internal_TemplateBase->fetch() #1 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(212): Enlight_View_Default->render() #2 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(238): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->renderTemplate() #3 engine/Library/Enlight/Controller/Plugins/ViewRenderer/Bootstrap.php(132): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->render() #4 engine/Library/Enlight/Event/Handler/Default.php(87): Enlight_Controller_Plugins_ViewRenderer_Bootstrap->onPostDispatch() #5 engine/Library/Enlight/Event/EventManager.php(214): Enlight_Event_Handler_Default->execute() #6 engine/Library/Enlight/Controller/Action.php(233): Enlight_Event_EventManager->notify() #7 engine/Library/Enlight/Controller/Dispatcher/Default.php(478): Enlight_Controller_Action->dispatch() #8 engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch() #9 engine/Shopware/Kernel.php(188): Enlight_Controller_Front->dispatch() #10 vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel->handle() #11 vendor/symfony/http-kernel/HttpCache/HttpCache.php(453): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle() #12 engine/Shopware/Components/HttpCache/AppCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward() #13 vendor/symfony/http-kernel/HttpCache/HttpCache.php(238): Shopware\Components\HttpCache\AppCache->forward() #14 engine/Shopware/Components/HttpCache/AppCache.php(102): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass() #15 shopware.php(122): Shopware\Components\HttpCache\AppCache->handle() #16 {main}
Kann mir wirklich niemand helfen?
ich bitte drum!
Hast du mal getestet, ob der Fehler noch auftritt, wenn du das Stripe Plugin deaktivierst?
wie kann ich stripe am einfachsten deaktivieren?
hab geschafft hab deaktiviert.
jetzt kommt nur der blaue hintergrung farbe, aber keine login
es ist alles blau
bitte um hilfe
Hast du mal den Cache geleert bzw. den Cache Ordner gelöscht? PayPal und WCB werden in der Fehlermeldung auch noch genannt. Es scheint beim Kompilieren des Themes etwas nicht geklappt zu haben.
wo finde ich den cache ordner?
wahnsinn danke hat gekplatt
ich kann mich wieder in backend einloggen
vielen vielen dank
Unter /var/cache/ ist dieser zu finden.
danke hat geklappt
vielen herzlichen dank
Das freut mich, sehr gerne. :slightly_smiling_face:
