Hey there, i was wondering if there is a way to update / override the sw-cms.constant.js file in the administration, i have to remove product description reviews cms element from the unique slots.
i am not sure if this is the correct way to do it but i got it to work by overriding the product detail components method where the validation happens and imported my custom sw-cm.constant.js file where i removed the entry from the array
