ErrorException {#33
#message: "Warning: include(/var/www/vhosts/meine-pfad/meineshop/vendor/composer/../shopware/core/Framework/Adapter/Cache/CacheIdLoader.php): Failed to open stream: No such file or directory"
#code: 0
#file: "/var/www/vhosts/meine-pfad/meine-shop/vendor/composer/ClassLoader.phpvar/www/vhosts/meine-pfad/meine-shop/vendor/composer/ClassLoader.php"
#line: 576
#severity: E_WARNING
trace: {
/var/www/vhosts/meine-pfad/meine-shop/vendor/composer/ClassLoader.php:576 { …}
/var/www/vhosts/meine-pfad/meine-shop/vendor/composer/ClassLoader.php:427 { …}
/var/www/vhosts/meine-pfad/meine-shop/vendor/shopware/core/Framework/Adapter/Kernel/KernelFactory.php:67 { …}
/var/www/vhosts/meine-pfad/meine-shop/bin/console:46 {
{closure}
› $kernel = KernelFactory::create(
› environment: $env,
arguments: {
$environment: "prod"
$debug: false
$classLoader: Composer\Autoload\ClassLoader {#1 …}
$pluginLoader: Shopware\Core\Framework\Plugin\KernelPluginLoader\DbalKernelPluginLoader {#16 …}
/var/www/vhosts/meine-pfad/meine-shop/vendor/autoload_runtime.php:24 { …}
/var/www/vhosts/meine-pfad/meine-shop/bin/console:17 { …}
2025-11-19T11:19:09+01:00 [info] User Deprecated: The "url" connection parameter is deprecated. Please use Doctrine\DBAL\Tools\DsnParser to parse a database url before calling Doctrine\DBAL\DriverManager. (DriverManager.php:257 called by DriverManager.php:173, https://github.com/doctrine/dbal/pull/5843, package doctrine/dbal)
2025-11-19T11:19:09+01:00 [info] User Deprecated: Not configuring a schema manager factory is deprecated. Use Doctrine\DBAL\Schema\DefaultSchemaManagerFactory which is going to be the default in DBAL 4. (Connection.php:227 called by DriverManager.php:197, https://github.com/doctrine/dbal/issues/5812, package doctrine/dbal)
2025-11-19T11:19:09+01:00 [error] Uncaught Warning: include(/var/www/vhosts/meine-pfad/meine-shop/vendor/composer/../shopware/core/Framework/Adapter/Cache/CacheIdLoader.php): Failed to open stream: No such file or directory
Im Abschnitt Remove Bin Directory werden die zwei problematischen Dateien public/index.php und bin/console gelöscht, so dass diese in einer neuen Version geladen werden können.
