maurer
1
Hello,
in shopware 4 and 5 it was possible to link to the system config save event. I do not find the way to do this in Shopware 6.
What do I want to do?
For one part of the configuration I want to react after saving the config of the plugin. I need to write the value to another part of the database.
Anybody has a solution?
Best regards, Rafael
Hi @maurer
Did you find any solution for this?
I need this in shopware 6 aswell.
Hi @KevinHansen and @maurer ,
did you two found a solution?
I need this too
maurer
4
@fragger93
Unfortunately not. My solution is to handle it over another route…
I think you can use the EntityWrittenEvent (or so) and have to check if the entity is a system_config Entity.
