SW-6 Production
Hi, everyone!
There are some major differences between the zip provided by the shopware site and the one in GitHub
Which one should be used for production?
It depends on your needs and experience - we offer a production template at Github, which is also used to build the install packages:
https://github.com/shopware/production
This allows you to use git for your project and will also use the stable releases.
