I have a fresh and clean installation with a basic theme:create plugin.
When using storefront:hot-proxy I get the following errors - resulting in a broken storefront.
Anybody any idea what I can do?
ERROR Failed to compile with 1 errors7:04:33 PM
error in /app/var/theme-entry.scss
Module build failed (from ../node_modules/sass-loader/lib/loader.js):
a&:hover {
Invalid CSS after "a": expected "{", was "&"
"&" may only be used at the beginning of a compound selector.
in /app/platform/src/Storefront/Resources/app/storefront/src/scss/skin/shopware/page/checkout/_cart-item.scss (line 38, column 6)
@ /app/var/theme-entry.scss 2:14-347 21:1-42:3 22:19-352
@ multi ./src/main.js /app/custom/plugins/MyPlugin/src/Resources/app/storefront/src/main.js /app/var/theme-entry.scss
Storefront proxy server started at http://localhost:9998
WAIT Compiling...7:04:33 PM
✔ Shopware 6 Storefront: Compiled with some errors in 3.99s (repeated 1 times)
✔ Shopware 6 Storefront: Compiled with some errors in 271.66ms
ERROR Failed to compile with 1 errors7:04:35 PM
a&:hover {
