Dear Team,
I hope this message finds you well. I am currently working on a project for my shop and would like to implement a sticky image feature. However, I am encountering difficulties with the right side, specifically with the Buy Box and the dropdown information.
When I add a new field below in Shopware, the sticky image remains in place, which is not the desired outcome. Should the Buy Box section be divided to accommodate multiple options?
Additionally, do you have any plugin recommendations that could assist with this integration?
Thank you for your help!
Best regards,
Roma
