Leider komme ich bei der Installation an dieser Stelle nicht weiter:
Type: ErrorException
Code: 2
Message: include(/var/www/web24965777/html/weko/vendor/composer/…/…/engine/Shopware/Models/Price/Group.php): failed to open stream: No such file or directory
File: /var/www/web24965777/html/weko/recovery/common/vendor/composer/ClassLoader.php
Line: 444
Trace
#0 /var/www/web24965777/html/weko/recovery/common/vendor/composer/ClassLoader.php(444): Slim\Slim::handleErrors(2, ‚include(/var/ww…‘, ‚/var/www/web249…‘, 444, Array)
#1 /var/www/web24965777/html/weko/recovery/common/vendor/composer/ClassLoader.php(444): include()
#2 /var/www/web24965777/html/weko/recovery/common/vendor/composer/ClassLoader.php(322): Composer\Autoload\includeFile(’/var/www/web249…’)
#3 [internal function]: Composer\Autoload\ClassLoader->loadClass(‚Shopware\Models…‘)
#4 [internal function]: spl_autoload_call(‚Shopware\Models…‘)
#5 /var/www/web24965777/html/weko/vendor/doctrine/common/lib/Doctrine/Common/ClassLoader.php(276): class_exists(‚Shopware\Models…‘, true)
#6 /var/www/web24965777/html/weko/vendor/doctrine/common/lib/Doctrine/Common/ClassLoader.php(240): Doctrine\Common\ClassLoader::typeExists(‚Shopware\Models…‘, true)
#7 /var/www/web24965777/html/weko/vendor/doctrine/orm/lib/Doctrine/ORM/Mapping/ClassMetadataInfo.php(1027): Doctrine\Common\ClassLoader::classExists(‚Shopware\Models…‘)
#8 /var/www/web24965777/html/weko/vendor/doctrine/orm/lib/Doctrine/ORM/Mapping/ClassMetadataFactory.php(272): Doctrine\ORM\Mapping\ClassMetadataInfo->validateAssociations()
#9 /var/www/web24965777/html/weko/vendor/doctrine/orm/lib/Doctrine/ORM/Mapping/ClassMetadataFactory.php(251): Doctrine\ORM\Mapping\ClassMetadataFactory->validateRuntimeMetadata(Object(Doctrine\ORM\Mapping\ClassMetadata), NULL)
#10 /var/www/web24965777/html/weko/vendor/doctrine/common/lib/Doctrine/Common/Persistence/Mapping/AbstractClassMetadataFactory.php(332): Doctrine\ORM\Mapping\ClassMetadataFactory->doLoadMetadata(Object(Doctrine\ORM\Mapping\ClassMetadata), NULL, false, Array)
#11 /var/www/web24965777/html/weko/vendor/doctrine/orm/lib/Doctrine/ORM/Mapping/ClassMetadataFactory.php(78): Doctrine\Common\Persistence\Mapping\AbstractClassMetadataFactory->loadMetadata(‚Shopware\Models…‘)
#12 /var/www/web24965777/html/weko/vendor/doctrine/common/lib/Doctrine/Common/Persistence/Mapping/AbstractClassMetadataFactory.php(216): Doctrine\ORM\Mapping\ClassMetadataFactory->loadMetadata(‚Shopware\Models…‘)
#13 /var/www/web24965777/html/weko/vendor/doctrine/common/lib/Doctrine/Common/Persistence/Mapping/AbstractClassMetadataFactory.php(115): Doctrine\Common\Persistence\Mapping\AbstractClassMetadataFactory->getMetadataFor(‚Shopware\Models…‘)
#14 /var/www/web24965777/html/weko/engine/Shopware/Components/Model/ModelManager.php(210): Doctrine\Common\Persistence\Mapping\AbstractClassMetadataFactory->getAllMetadata()
#15 /var/www/web24965777/html/weko/engine/Shopware/Components/Model/ModelManager.php(194): Shopware\Components\Model\ModelManager->regenerateAttributeProxies(Array)
#16 /var/www/web24965777/html/weko/recovery/install/src/ContainerProvider.php(125): Shopware\Components\Model\ModelManager->generateAttributeModels()
#17 /var/www/web24965777/html/weko/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))
#18 /var/www/web24965777/html/weko/recovery/install/src/ContainerProvider.php(131): Pimple\Container->offsetGet(‚shopware.contai…‘)
#19 /var/www/web24965777/html/weko/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))
#20 /var/www/web24965777/html/weko/recovery/install/src/ContainerProvider.php(144): Pimple\Container->offsetGet(‚shopware.theme_…‘)
#21 /var/www/web24965777/html/weko/recovery/common/vendor/pimple/pimple/src/Pimple/Container.php(118): Shopware\Recovery\Install\ContainerProvider->Shopware\Recovery\Install{closure}(Object(Pimple\Container))
#22 /var/www/web24965777/html/weko/recovery/install/src/app.php(496): Pimple\Container->offsetGet(‚theme.service‘)
#23 [internal function]: {closure}()
#24 /var/www/web24965777/html/weko/recovery/common/vendor/slim/slim/Slim/Route.php(468): call_user_func_array(Object(Closure), Array)
#25 /var/www/web24965777/html/weko/recovery/common/vendor/slim/slim/Slim/Slim.php(1355): Slim\Route->dispatch()
#26 /var/www/web24965777/html/weko/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#27 /var/www/web24965777/html/weko/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#28 /var/www/web24965777/html/weko/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#29 /var/www/web24965777/html/weko/recovery/common/vendor/slim/slim/Slim/Slim.php(1300): Slim\Middleware\PrettyExceptions->call()
#30 /var/www/web24965777/html/weko/recovery/install/index.php(75): Slim\Slim->run()
#31 {main}
