Habe folgendes problem,
The HOME or COMPOSER_HOME environment variable must be set for composer to run correctly
alles komplett neu instalieren.
RuntimeException:
at vendor/composer/composer/src/Composer/Factory.php:744
at Composer\Factory::getUserDir()
(vendor/composer/composer/src/Composer/Factory.php:72)
at Composer\Factory::getHomeDir()
(vendor/composer/composer/src/Composer/Factory.php:184)
at Composer\Factory::createConfig(object(NullIO), ‚/var/www/web22849527/html/vswn‘)
(vendor/composer/composer/src/Composer/Factory.php:354)
at Composer\Factory->createComposer(object(NullIO), array(‚name‘ => ‚shopware/production‘, ‚type‘ => ‚project‘, ‚license‘ => ‚MIT‘, ‚config‘ => array(‚optimize-autoloader‘ => true, ‚platform‘ => array(‚php‘ => ‚7.4.3‘), ‚sort-packages‘ => true, ‚allow-plugins‘ => array(‚composer/package-versions-deprecated‘ => true)), ‚prefer-stable‘ => true, ‚minimum-stability‘ => ‚stable‘, ‚scripts‘ => array(‚pre-install-cmd‘ => array(‚[ ! -f vendor/autoload.php ] || $PHP_BINARY bin/console system:update:prepare‘), ‚pre-update-cmd‘ => array(‚[ ! -f vendor/autoload.php ] || $PHP_BINARY bin/console system:update:prepare‘), ‚post-install-cmd‘ => array(‚@composer install --working-dir vendor/shopware/recovery --no-interaction --no-scripts‘, ‚@composer install --working-dir=vendor/shopware/recovery/Common --no-interaction --optimize-autoloader --no-suggest‘, ‚[ ! -f vendor/autoload.php ] || $PHP_BINARY bin/console system:update:finish‘), ‚post-update-cmd‘ => array(‚@composer install --working-dir vendor/shopware/recovery --no-interaction --no-scripts‘, ‚@composer install --working-dir=vendor/shopware/recovery/Common --no-interaction --optimize-autoloader --no-suggest‘, ‚[ ! -f vendor/autoload.php ] || $PHP_BINARY bin/console system:update:finish‘)), ‚autoload‘ => array(‚psr-4‘ => array(‚Shopware\Production' => ‚src/‘)), ‚repositories‘ => array(array(‚type‘ => ‚path‘, ‚url‘ => ‚custom/plugins//packages/‘, ‚options‘ => array(‚symlink‘ => true)), array(‚type‘ => ‚path‘, ‚url‘ => ‚custom/static-plugins/', ‚options‘ => array(‚symlink‘ => true))), ‚require‘ => array(‚php‘ => ‚^7.4.3 || ^8.0‘, ‚composer-runtime-api‘ => ‚^2.0‘, ‚shopware/administration‘ => ‚~v6.4.0‘, ‚shopware/core‘ => ‚~v6.4.0‘, ‚shopware/elasticsearch‘ => ‚~v6.4.0‘, ‚shopware/recovery‘ => ‚~v6.4.0‘, ‚shopware/storefront‘ => ‚~v6.4.0‘), ‚require-dev‘ => array(‚ext-openssl‘ => '‘, ‚ext-tokenizer‘ => ‚', ‚ext-xmlwriter‘ => '‘, ‚defuse/php-encryption‘ => ‚~2.2.1‘, ‚dms/phpunit-arraysubset-asserts‘ => ‚^0.2.1‘, ‚fakerphp/faker‘ => ‚~1.14.1‘, ‚johnkary/phpunit-speedtrap‘ => ‚~3.3.0‘, ‚league/flysystem-memory‘ => ‚~1.0.2‘, ‚maltyxx/images-generator‘ => ‚~1.0.0‘, ‚mbezhanov/faker-provider-collection‘ => ‚~2.0.1‘, ‚nikic/php-parser‘ => ‚~4.13.2‘, ‚opis/json-schema‘ => ‚~1.0.19‘, ‚phpunit/php-code-coverage‘ => ‚~9.2.14‘, ‚phpunit/phpunit‘ => ‚~9.5.17‘, ‚smalot/pdfparser‘ => ‚~0.14.0‘, ‚symfony/browser-kit‘ => ‚~4.4 || ~5.2.3 || ~5.3.0 || ~5.4.0‘, ‚symfony/dependency-injection‘ => ‚~4.4 || ~5.2.3 || ~5.3.0 || ~5.4.0‘, ‚symfony/css-selector‘ => ‚^5.3‘, ‚symfony/dom-crawler‘ => ‚~4.4 || ~5.2.3 || ~5.3.0 || ~5.4.0‘, ‚symfony/phpunit-bridge‘ => ‚~4.4 || ~5.2.3 || ~5.3.0 || ~5.4.0‘, ‚symfony/stopwatch‘ => ‚~4.4 || ~5.2.3 || ~5.3.0 || ~5.4.0‘, ‚symfony/var-dumper‘ => ‚~4.4 || ~5.2.3 || ~5.3.0 || ~5.4.0‘, ‚symfony/web-profiler-bundle‘ => ‚~4.4 || ~5.2.3 || ~5.3.0 || ~5.4.0‘)), false, ‚/var/www/web22849527/html/vswn‘)
(vendor/shopware/core/Framework/Plugin/Composer/Factory.php:19)
at Shopware\Core\Framework\Plugin\Composer\Factory::createComposer(‘/var/www/web22849527/html/vswn’)
(var/cache/dev/ContainerQqGBtJI/getEnvironmentRequirementsValidatorService.php:28)
at ContainerQqGBtJI\getEnvironmentRequirementsValidatorService::do(object(Shopware_Core_Installer_InstallerKernelDevDebugContainer), true)
(var/cache/dev/ContainerQqGBtJI/Shopware_Core_Installer_InstallerKernelDevDebugContainer.php:191)
at ContainerQqGBtJI\Shopware_Core_Installer_InstallerKernelDevDebugContainer->load(‚getEnvironmentRequirementsValidatorService.php‘)
(var/cache/dev/ContainerQqGBtJI/getRequirementsControllerService.php:26)
at ContainerQqGBtJI\getRequirementsControllerService::ContainerQqGBtJI{closure}()
(vendor/shopware/core/Installer/Controller/RequirementsController.php:45)
at Shopware\Core\Installer\Controller\RequirementsController->requirements(object(Request))
(vendor/symfony/http-kernel/HttpKernel.php:153)
at Symfony\Component\HttpKernel\HttpKernel->handleRaw(object(Request), 1)
(vendor/symfony/http-kernel/HttpKernel.php:75)
at Symfony\Component\HttpKernel\HttpKernel->handle(object(Request), 1, true)
(vendor/symfony/http-kernel/Kernel.php:202)
at Symfony\Component\HttpKernel\Kernel->handle(object(Request))
(public/index.php:85)
