Shopware - Extjs - Can not send valid Ajax request from plugin config window
Hi!
Shopware backend extjs question. Shopware 5.4.6 version
I have task to implement button on plugin config window which will send request on backend controller. So I implemented button and wrote code to execute ajax:
            Connect
            Verbinde
            Connect
And when I click to button I get status 500 with message in apache log:
Call to undefined method Shopware_Proxies_ShopwareControllersBackendEtsyUserDataProxy::setFront()
So, is there proper way to write this request or I misunderstood something? Or it is a bug?
Controllers Folder is reserved for the old controller system. Just name your folder to „Controller“ or move this controller to new „controller“ folder and it will work
namespace PluginName\Controller\Backend;
class YourController extends \Shopware_Controllers_Backend_ExtJs
public function testAction()
and in your config.xml
        <name>buttonTest</name>
        <label lang="de">xxxxx</label>
        <label lang="en">xxxxx</label>
        <options>
            <handler>
                <![CDATA[
                function() {
                  Ext.Ajax.request({
                    url: 'YourController/test',
                    success: function (response) {
                    failure: function (response) {
            </handler>
        </options>
    </element>
