Hi! When I’m adding LI-tag to the snippet - SW removes this tag after saving. But tag A-tag works fine. How can I save LI-tags in the snippet as well?
Hey @yurii.k
this probably happens due to the html_sanitizer.
Shopware 6 - Tutorials & FAQs - HTML Sanitizer
You will need to whitelist the LI-tags in your z-shopware.yaml for snippets.
This would look something like this:
shopware:
html_sanitizer:
sets:
- name: snippet
tags: [ "LI" ]
attributes: [ "...", "...", "..." ]
options:
- key: HTML.Trusted
value: true
- key: CSS.Trusted
value: true
You will just need to add the attributes that you also want to use with the LI-tags ![]()
