Hallo nochmal,
nächste Frage: Nach dem Shopware Update auf 6.5.7.2 wurde nun der Code für ein Iframe automatisch entfernt in der Erlebniswelt… Hab nun eine z-shopware.yaml angelegt und diverse Tags freigegeben, mit iframe soll es aber etwas komplizierter sein, da man die src des iframes explizit freigeben muss wie ich in der Doku lesen konnte. Da wird aber kein explizites Beispiel gegeben. Kann mir einer sagen, wie ich es in die z-shopware.yaml schreiben muss, um das iframe freizugeben?
Hier meine z-shopware.yaml:
shopware:
html_sanitizer:
sets:
- name: basic
tags: ["a", "abbr", "acronym", "address", "b", "bdo", "big", "blockquote", "br", "caption", "center", "cite", "code", "col", "colgroup", "dd", "del", "dfn", "dir", "div", "dl", "dt", "em", "font", "h1", "h2", "h3", "h4", "h5", "h6", "hr", "i", "ins", "kbd", "li", "menu", "ol", "p", "pre", "q", "s", "samp", "small", "span", "strike", "strong", "sub", "sup", "table", "tbody", "td", "tfoot", "th", "thead", "tr", "tt", "u", "ul", "var", "img"]
attributes: ["align", "bgcolor", "border", "cellpadding", "cellspacing", "cite", "class", "clear", "color", "colspan", "dir", "face", "frame", "height", "href", "id", "lang", "name", "noshade", "nowrap", "rel", "rev", "rowspan", "scope", "size", "span", "start", "style", "summary", "title", "type", "valign", "value", "width", "target", "src", "alt", "iframe"]
options:
- key: Attr.AllowedFrameTargets
values: ['_blank', '_self', '_parent', '_top']
- key: Attr.AllowedRel
values: ['nofollow', 'print']
- key: Attr.EnableID
value: true
- name: media
tags: ["img"]
attributes: ["src", "alt"]
- name: script
tags: ["script"]
options:
- key: HTML.Trusted
value: true
- name: tidy
options:
- key: Output.TidyFormat
value: true
- name: bootstrap
tags: ["a", "span"]
attributes: ["role", "aria-label", "aria-labelledly", "aria-current", "aria-expanded", "aria-controls", "aria-hidden", "aria-describedby", "tabindex", "aria-modal", "data-bs-toggle", "data-bs-target", "data-bs-dismiss", "data-bs-slide", "data-bs-slide-to", "data-bs-parent", "data-bs-config", "data-bs-content", "data-bs-spy"]
custom_attributes:
- tags: ["a", "span"]
attributes: ["href", "role", "aria-label", "aria-labelledly", "aria-current", "aria-expanded", "aria-controls", "aria-hidden", "aria-describedby", "tabindex", "aria-modal", "data-bs-toggle", "data-bs-target", "data-bs-dismiss", "data-bs-slide", "data-bs-slide-to", "data-bs-parent", "data-bs-config", "data-bs-content", "data-bs-spy"]
- name: snippet
tags: ["a"]
attributes: ["data-url", "data-ajax-modal"]
custom_attributes:
- tags: ["a"]
