Shopware 6 generate Pdf
I’ve created an action button in admin product section. And when it’s clicked I want to generate or download a pdf file. I don’t know how to use the shopware 6 built-in pdf renderer. Can anyone help me? Or is there a documentation for this?
hi,
please a small piece of code below. Of cause you can also use twig to generate the content
use Dompdf\Dompdf;
use Dompdf\Options;
public function generatePdf($htmlContent, $mode = 'return', $filename = 'output.pdf') {
        $options = new Options();
        $options->set('defaultFont', 'Helvetica');
        $options->set('isRemoteEnabled', true);
        $dompdf = new Dompdf($options);
        $a4 = [0, 0, 595.28, 841.89];
        // $a4 = 'a4';
        $dompdf->setPaper($a4, 'portrait');
        $dompdf->loadHtml($htmlContent);
        $dompdf->render();
        if ($mode == 'return') {
            return $dompdf->output();
        } elseif (($mode == 'echo') or ($mode == 'stream')) {
            $dompdf->stream($filename, ['Attachment' => true, 'compress' => true]);
        } elseif ($mode == 'save') {
            file_put_contents($filename, $dompdf->output());
        return true;
