Shopware 5.2.5 Update liefert jetzt schon mehrere Probleme bei mir
Hallo Comunity, Kunden können seit Shopwareupdate 5.2.5 keine Bestellungen mehr durchführen. Im Checkout kommt folgende Fehlermeldung:
SQLSTATE[HY093]: Invalid parameter number: number of bound variables does not match number of tokens in engine/Library/Zend/Db/Statement/Pdo.php on line 234
 #0 engine/Library/Zend/Db/Statement.php(303): Zend\_Db\_Statement\_Pdo-\>\_execute(Array) #1 engine/Library/Zend/Db/Adapter/Abstract.php(480): Zend\_Db\_Statement-\>execute(Array) #2 engine/Library/Zend/Db/Adapter/Pdo/Abstract.php(238): Zend\_Db\_Adapter\_Abstract-\>query('\n INSERT...', Array) #3 engine/Library/Enlight/Components/Db/Adapter/Pdo/Mysql.php(96): Zend\_Db\_Adapter\_Pdo\_Abstract-\>query('\n INSERT...', Array) #4 engine/Library/Enlight/Components/Db/Adapter/Pdo/Mysql.php(131): Enlight\_Components\_Db\_Adapter\_Pdo\_Mysql-\>query('\n INSERT...', Array) #5 engine/Shopware/Core/sOrder.php(1390): Enlight\_Components\_Db\_Adapter\_Pdo\_Mysql-\>executeUpdate('\n INSERT...', Array) #6 engine/Shopware/Core/sOrder.php(762): sOrder-\>sSaveShippingAddress(Array, '126') #7 engine/Shopware/Controllers/Frontend/Checkout.php(855): sOrder-\>sSaveOrder() #8 engine/Shopware/Controllers/Frontend/Checkout.php(372): Shopware\_Controllers\_Frontend\_Checkout-\>saveOrder() #9 engine/Library/Enlight/Controller/Action.php(159): Shopware\_Controllers\_Frontend\_Checkout-\>finishAction() #10 engine/Library/Enlight/Controller/Dispatcher/Default.php(523): Enlight\_Controller\_Action-\>dispatch('finishAction') #11 engine/Library/Enlight/Controller/Front.php(223): Enlight\_Controller\_Dispatcher\_Default-\>dispatch(Object(Enlight\_Controller\_Request\_RequestHttp), Object(Enlight\_Controller\_Response\_ResponseHttp)) #12 engine/Shopware/Kernel.php(176): Enlight\_Controller\_Front-\>dispatch() #13 vendor/symfony/http-kernel/HttpCache/HttpCache.php(487): Shopware\Kernel-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #14 engine/Shopware/Components/HttpCache/AppCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true, NULL) #15 vendor/symfony/http-kernel/HttpCache/HttpCache.php(258): Shopware\Components\HttpCache\AppCache-\>forward(Object(Symfony\Component\HttpFoundation\Request), true) #16 vendor/symfony/http-kernel/HttpCache/HttpCache.php(275): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>pass(Object(Symfony\Component\HttpFoundation\Request), true) #17 engine/Shopware/Components/HttpCache/AppCache.php(133): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>invalidate(Object(Symfony\Component\HttpFoundation\Request), true) #18 vendor/symfony/http-kernel/HttpCache/HttpCache.php(206): Shopware\Components\HttpCache\AppCache-\>invalidate(Object(Symfony\Component\HttpFoundation\Request), true) #19 engine/Shopware/Components/HttpCache/AppCache.php(114): Symfony\Component\HttpKernel\HttpCache\HttpCache-\>handle(Object(Symfony\Component\HttpFoundation\Request), 1, true) #20 shopware.php(101): Shopware\Components\HttpCache\AppCache-\>handle(Object(Symfony\Component\HttpFoundation\Request)) #21 {main}
______________________________
Hat jemand Rat?
Ok, hab den Übeltäter. Es war das DHL Plugin von Shopware. Ist ein Update in Produktion?
