Bekomme folgende Meldung bei der Analyse: Die Seite ist unter folgenden URLs zu erreichn (Statuscode / URL): HTTP Status 301: http://…de HTTP Status 301: https://…de HTTP Status 200: http://www…de HTTP Status 200: https://www…de Die Seite soll aber nur unter www erreichbar sein. RewriteEngine on #RewriteBase /shopware/ # Https config for the backend #RewriteCond %{HTTPS} !=on #RewriteRule backend/(.*) https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301] RewriteRule shopware.dll shopware.php RewriteRule files/documents/.* engine [NC,L] RewriteRule backend/media/(.*) media/1 [NC,L] RewriteCond %{REQUEST\_URI} !(\/(engine|files|templates)\/) RewriteCond %{REQUEST\_URI} !(\/media\/(archive|banner|image|music|pdf|unknown|video)\/) RewriteCond %{REQUEST\_FILENAME} !-f RewriteCond %{REQUEST\_FILENAME} !-d RewriteRule ^(.\*) shopware.php [PT,L,QSA] # Fix missing authorization-header on fast_cgi installations RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L] # Staging-Rules start #SetEnvIf Host “staging.test.shopware.in” ENV=staging DirectoryIndex index.html DirectoryIndex index.php DirectoryIndex shopware.php # Disables download of configuration
Deny from all
# Enable gzip compression
AddOutputFilterByType DEFLATE text/html text/xml text/plain text/css text/javascript application/json
ExpiresActive on
ExpiresDefault “access plus 1 month”
FileETag None
Header append Cache-Control “public”
Header unset ETag
# Disables auto directory index
Options -Indexes
Options -MultiViews
php_value memory_limit 128M
php_value max_execution_time 120
php_value upload_max_filesize 20M
php_flag phar.readonly off
php_flag magic_quotes_gpc off
php_flag session.auto_start off
php_flag suhosin.session.cryptua off
php_flag zend.ze1_compatibility_mode off
# AddType x-mapp-php5 .php # AddHandler x-mapp-php5 .php
Bin zwar bei Timmehosting aber irgendwie klappt es nicht so wie ich mir vorstelle. Wollte duplicate content vermeiden und deswegen die Seite nicht über 4 verschiedene versionen laufen lassen. Sobald jemand …de eingibt ohne wwww, so soll diese dann im browser nur
