Regenerate Thumbnails
Hi there,
The thumbnails aren’t always generated properly after migration. I found the media:generate-thumbnails command in bin/console to generate the thumbnails but this doesn’t help me because it just skips the ''already generated" thumbnails. I would like to realy REgenerate them. Is there a way to remove all the thumbnails and let them regenerate by the console?
Kind Regards,
Dylan.
Hi Dylan,
i did check this in my environment and indeed it is right that thumbnails will not be regenerated if already existing.
You will need to clear the „media_thumbnail“ table in your database to regenerate the thumbnails.
I also added a ticket to our issue tracker so that it can be changed in future updates:
https://issues.shopware.com/issues/NEXT-7754
Kind regards,
Tim
If I do this, no thumbnails will be shown in the frontend. Only the large source file will be scaled down and with bin/console media:generate-thumbnails no thumbs will be generated.
It works now: I deleted the public/thumbnail/* content and now it works like expected.
