Good evening,
in a plugin with 5.2 system, I would like to edit the template used in the slider, for example in a page with this url:
The template folder „Resources/view“ is loaded (because other *.tpl in the plugins are loaded), but if I extend „frontend/_includes/product_slider_items.tpl“ in my plugin, the system loads the original „product_slider_items.tpl“ in Bare theme instead. I already cleared the cache and compiled the theme but it still doesn’t load.
Any clues on how can I modify „product_slider_items.tpl“ in my own plugin?
Edit
I tried to user productBoxLayout parameter and choose my own template in frontend/listing/box_article.tpl, the parameter is passed, but I have the same problem: box_article.tpl of the plugin is not loaded!
My frontend/listing/box_article.tpl is this:
{extends file="parent:frontend/listing/box_article.tpl"}
{block name="frontend_listing_box_article_includes_additional"}
{if $productBoxLayout == 'myslider'}
{include file="frontend/listing/product-box/box-myslider.tpl"}
{else}
{include file="frontend/listing/product-box/box-basic.tpl" productBoxLayout="basic"}
{/if}
{/block}
Solved
In getSubscribedEvents() I called Enlight_Controller_Action_PostDispatchSecure instead of Enlight_Controller_Action_PostDispatchSecure_Frontend because the sliders are under Widgets and not Frontend, I don’t specify Widget because I also need to trigger the templates for the frontend:
return array(
'Enlight_Controller_Action_PostDispatchSecure' => 'addTemplateDir',
