Hello,
I get the following error when updating shopware to version 6.3.0.0
Error
Received the following error message:
An exception occurred while executing ’ CREATE TABLE language ( id BINARY(16) NOT NULL, name VARCHAR(50) COLLATE utf8mb4_unicode_ci NOT NULL, parent_id BINARY(16) NULL, locale_id BINARY(16) NOT NULL, translation_code_id BINARY(16) NULL, custom_fields JSON NULL, created_at DATETIME(3) NOT NULL, updated_at DATETIME(3) NULL, PRIMARY KEY (id), UNIQUE uniq.translation_code_id (translation_code_id), KEY idx.language.translation_code_id (translation_code_id), KEY idx.language.language_id_parent_language_id (id, parent_id), CONSTRAINT json.language.custom_fields CHECK (JSON_VALID(custom_fields)), CONSTRAINT fk.language.parent_id FOREIGN KEY (parent_id) REFERENCES language (id) ON DELETE CASCADE ON UPDATE CASCADE ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci; ': SQLSTATE[42S01]: Base table or view already exists: 1050 Table ‚language‘ already exists
Response
{„valid“:false,„errorMsg“:„An exception occurred while executing '\n CREATE TABLE language (\n id BINARY(16) NOT NULL,\n name VARCHAR(50) COLLATE utf8mb4_unicode_ci NOT NULL,\n parent_id BINARY(16) NULL,\n locale_id BINARY(16) NOT NULL,\n translation_code_id BINARY(16) NULL,\n custom_fields JSON NULL,\n created_at DATETIME(3) NOT NULL,\n updated_at DATETIME(3) NULL,\n PRIMARY KEY (id),\n UNIQUE uniq.translation_code_id (translation_code_id),\n KEY idx.language.translation_code_id (translation_code_id),\n KEY idx.language.language_id_parent_language_id (id, parent_id),\n CONSTRAINT json.language.custom_fields CHECK (JSON_VALID(custom_fields)),\n CONSTRAINT fk.language.parent_id FOREIGN KEY (parent_id)\n REFERENCES language (id) ON DELETE CASCADE ON UPDATE CASCADE\n ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci;\n ':\n\nSQLSTATE[42S01]: Base table or view already exists: 1050 Table ‚language‘ already exists“}
Removing the „language“ table from the database does not help (information appears that the ‚locale‘ table exists, after removing it, the error informs that the language table does not exist …).
An attempt was made to set a parameter ‚log_bin_trust_function_creators = ON‘, but nothing helps. All plugins were disabled prior to update.
