Hallo Shopware Gemeinde,
beim update von Schopware 5.1.6 auf 5.2 kam folgender Fehler:
Slim Application Error
Type: ErrorException
Code: 8
Message: unserialize(): Error at offset 169 of 174 bytes
File: /shops/stagingshop/engine/Shopware/Components/Model/DBAL/Types/AllowInvalidArrayType.php
Line: 57
Trace
#0 [internal function]: Slim\Slim::handleErrors(8, 'unserialize(): ...', '/kunden/486365_...', 57, Array)
#1 /shops/stagingshop/engine/Shopware/Components/Model/DBAL/Types/AllowInvalidArrayType.php(57): unserialize('a:1:{s:8:"boxLa...')
#2 /shops/stagingshop/vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/AbstractHydrator.php(297): Shopware\Components\Model\DBAL\Types\AllowInvalidArrayType->convertToPHPValue('a:1:{s:8:"boxLa...', Object(Doctrine\DBAL\Platforms\MySqlPlatform))
#3 /shops/stagingshop/vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/ObjectHydrator.php(333): Doctrine\ORM\Internal\Hydration\AbstractHydrator->gatherRowData(Array, Array, Array)
#4 /shops/stagingshop/vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/ObjectHydrator.php(165): Doctrine\ORM\Internal\Hydration\ObjectHydrator->hydrateRowData(Array, Array)
#5 /shops/stagingshop/vendor/doctrine/orm/lib/Doctrine/ORM/Internal/Hydration/AbstractHydrator.php(147): Doctrine\ORM\Internal\Hydration\ObjectHydrator->hydrateAllData()
#6 /shops/stagingshop/vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(978): Doctrine\ORM\Internal\Hydration\AbstractHydrator->hydrateAll(Object(PDOStatement), Object(Doctrine\ORM\Query\ResultSetMapping), Array)
#7 /shops/stagingshop/vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(924): Doctrine\ORM\AbstractQuery->executeIgnoreQueryCache(NULL, 1)
#8 /shops/stagingshop/vendor/doctrine/orm/lib/Doctrine/ORM/AbstractQuery.php(766): Doctrine\ORM\AbstractQuery->execute(NULL, 1)
#9 /shops/stagingshop/engine/Shopware/Components/Theme/Configurator.php(321): Doctrine\ORM\AbstractQuery->getOneOrNullResult(1)
#10 /shops/stagingshop/engine/Shopware/Components/Theme/Configurator.php(107): Shopware\Components\Theme\Configurator->getTemplate(Object(Shopware\Themes\Responsive\Theme))
#11 /shops/stagingshop/engine/Shopware/Components/Theme/Installer.php(154): Shopware\Components\Theme\Configurator->synchronize(Object(Shopware\Themes\Responsive\Theme))
#12 /shops/stagingshop/engine/Shopware/Components/Theme/Installer.php(116): Shopware\Components\Theme\Installer->synchronizeThemes()
#13 /shops/stagingshop/recovery/update/src/app.php(165): Shopware\Components\Theme\Installer->synchronize()
#14 [internal function]: {closure}()
#15 /shops/stagingshop/recovery/common/vendor/slim/slim/Slim/Route.php(462): call_user_func_array(Object(Closure), Array)
#16 /shops/stagingshop/recovery/common/vendor/slim/slim/Slim/Slim.php(1326): Slim\Route->dispatch()
#17 /shops/stagingshop/recovery/common/vendor/slim/slim/Slim/Middleware/Flash.php(85): Slim\Slim->call()
#18 /shops/stagingshop/recovery/common/vendor/slim/slim/Slim/Middleware/MethodOverride.php(92): Slim\Middleware\Flash->call()
#19 /shops/stagingshop/recovery/common/vendor/slim/slim/Slim/Middleware/PrettyExceptions.php(67): Slim\Middleware\MethodOverride->call()
#20 /shops/stagingshop/recovery/common/vendor/slim/slim/Slim/Slim.php(1271): Slim\Middleware\PrettyExceptions->call()
#21 /shops/stagingshop/recovery/update/index.php(46): Slim\Slim->run()
#22 {main}
Kann mir jemand hier helfen?
Danke!
VG Fabian
