Hallo zusammmen,
wir bekommen nun folgendes Problem. Habt ihr hierzu eine Idee?
Uncaught PHP Exception Doctrine\DBAL\Exception\DeadlockException: „An exception occurred while executing ‚DELETE FROM pickware_erp_order_pickability WHERE order_id IN ( SELECT order.id FROM order LEFT JOIN state_machine_state AS order_state ON order.state_id = order_state.id LEFT JOIN pickware_shopware_extensions_order_configuration AS orderConfiguration ON order.id = orderConfiguration.order_id AND order.version_id = orderConfiguration.order_version_id LEFT JOIN order_delivery ON order_delivery.id = orderConfiguration.primary_order_delivery_id AND order_delivery.version_id = orderConfiguration.primary_order_delivery_version_id LEFT JOIN state_machine_state AS orderDeliveryState ON order_delivery.state_id = orderDeliveryState.id WHERE (order_state.technical_name IN (?, ?) OR orderDeliveryState.technical_name IN (?, ?)) AND order.id IN (?) )‘ with params [„cancelled“, „completed“, „cancelled“, „shipped“, „\xe6\xe8\x25\x33\xb8\x1a\x46\xd7\xa7\xca\x0e\x7f\x1f\x1d\xa7\x75“]: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction“ at /var/www/clients/client1/web1/web/releases/20220113161245/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php line 51 {„exception“:„[object] (Doctrine\DBAL\Exception\DeadlockException(code: 0): An exception occurred while executing ‚DELETE FROM pickware_erp_order_pickability\n WHERE order_id IN (\n SELECT\n order.id\n FROM order\n LEFT JOIN state_machine_state AS order_state\n ON order.state_id = order_state.id\n LEFT JOIN pickware_shopware_extensions_order_configuration AS orderConfiguration\n ON order.id = orderConfiguration.order_id\n AND order.version_id = orderConfiguration.order_version_id\n LEFT JOIN order_delivery\n ON order_delivery.id = orderConfiguration.primary_order_delivery_id\n AND order_delivery.version_id = orderConfiguration.primary_order_delivery_version_id\n LEFT JOIN state_machine_state AS orderDeliveryState\n ON order_delivery.state_id = orderDeliveryState.id\n\n WHERE\n (order_state.technical_name IN (?, ?)\n OR orderDeliveryState.technical_name IN (?, ?))\n AND order.id IN (?)\n )‘ with params ["cancelled", "completed", "cancelled", "shipped", "\xe6\xe8\x25\x33\xb8\x1a\x46\xd7\xa7\xca\x0e\x7f\x1f\x1d\xa7\x75"]:\n\nSQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction at /var/www/clients/client1/web1/web/releases/20220113161245/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php:51)\n[previous exception] [object] (Doctrine\DBAL\Driver\PDO\Exception(code: 40001): SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction at /var/www/clients/client1/web1/web/releases/20220113161245/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDO/Exception.php:18)\n[previous exception] [object] (PDOException(code: 40001): SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction at /var/www/clients/client1/web1/web/releases/20220113161245/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php:117)“}
Gruß
Markus
