Hello Shopware community,
This is more or less a continuation of my previous post here. Same problem, slightly diffirent setting.
Again, i am trying to load a custom template on a custom controller but i am getting the following error.
Unable to load template snippet ‚frontend/event_detail/index.tpl|frontend/plugins/seo/index.tpl‘ in engine/Library/Smarty/sysplugins/smarty_internal_templatebase.php on line 127
The difference with this problem compared to my previous one, is that this time i am not subscribing to a event to load the controller, but i am redirecting the user from one controller to another controller through an html a tag.
I am using the following code in the first controllers template, this is where the redirect happens:
{extends file="parent:frontend/index/index.tpl"}
{block name="frontend_index_content_left"}{/block}
{block name="frontend_index_content"}
{foreach $messages as $message}
{$message}
View
{/foreach}
{/block}
I am getting redirected to the correct page but the template isn’t loading and the error stated above is generated.
My directory structure looks like this:
The code inside my EventDetail.php file is a simple indexAction() that assigns an array to the template.
As far as i can tell i have the correct directory structure and correct names for my files. Here is a download link to my plugin.
Any help would be greatly appreciated ![]()
thanks again for the help
