Plugin priority
Hi all
 I try to develop new plugin to change footer. And when I install it on dev server it works. But on production not. How I can set priority to plugin? I mean firstly use footer from my plugin and only then from another plugins/themes
It is like
  1. Core
  2. Plug-Ins
  3. Themes
This is how shopware inherits in SW5.
Now you have 2 options to overwrite the default inheritance:
  1. Tell the theme via
    protected $injectBeforePlugins = true
that it should load before the plug-ins
  1. register your functions to the subscribeEvents of your plug-ins with an higher position as the other plug-ins or themes via a third parameter
So, I wrote
   public function install()
        $this->subscribeEvent(
            ‚Enlight_Controller_Action_PostDispatchSecure_Frontend‘,
            ‚onFrontendPostDispatch‘,
           0
        return true;
and see nothing. Can you help me?
Well, Zero is a pretty low value for a higher position :wink:
Try PHP_INT_MAX
and if this works try a more feasible value.
Ohh, its not work too.
Maybe exists some way to known what tpl files shopware use to render page? Like debug or something else
anybody can’t help? (
Ok, another idea came to my mind:
Since this is a frontend-extension i am assuming you are appending or prepending some smarty blocks.
There is a known bug that two Plug-Ins appending/prepending the same smarty block won’t both append/prepend. So instead of
{block name='x' append}
//my code
{/block}
use
{block name='x'}
{$smarty.block.parent}
//my code
{/block}
(for prepend operation just swap //my code with {$smarty.block.parent}
Hi
it does not help(
my code is
{extends file="parent:frontend/index/footer.tpl"}
{block name="frontend_index_shopware_footer_copyright"}
test
{/block}
But I wonder about right way to tpl file.
In plugin I use Views/frontend/index/footer.tpl
please post your onFrontendPostDispatch
Sorry, can you explain? I new shopware plugin developer and don’t understand what do you mind
           0
        return true;
So you registered your own function onFrontendPostDispatch.
If you don’t have such function you should start over here:
I have such function
    public function onFrontendPostDispatch(Enlight_Event_EventArgs $args)
        /** @var \Enlight_Controller_Action $controller */
        $controller = $args->get('subject');
        $view = $controller->View();
        $view->addTemplateDir(
            __DIR__. '/Views'
Any others idea?(
@Maksim‍ You may have a look at this very simple Plugin which changes the newsletter section in the footer: https://github.com/hostianer/HostiReplaceNewsletter
It does not help because shopware when renredering page use tpl files in unknown order. I need to know what tpl files uses for render page
the general hierarchy can be accessed with this command:
Shopware()->Template()->getTemplateDir()
It will print out something like this:
Array
    [0] => /var/www/html/52/engine/Shopware/Plugins/Local/Frontend/SwagPromotion/Views/
    [1] => /var/www/html/52/themes/Frontend/Responsive/
    [2] => /var/www/html/52/themes/Frontend/Bare/
So in my case, it will look up a given template file in the order SwagPromotion-Plugin, Responsive-Theme, Bare-Theme. If you have a custom theme in place, the hierarchy will look like this:
Array
    [0] => /var/www/html/52/themes/Frontend/CustomTheme/
    [1] => /var/www/html/52/engine/Shopware/Plugins/Local/Frontend/SwagPromotion/Views/
    [2] => /var/www/html/52/themes/Frontend/Responsive/
    [3] => /var/www/html/52/themes/Frontend/Bare/
So in this case, the custom theme will extend / overwrite my plugin’s template.
Daniel
@Maksim‍ Which shopware version have you installed?
You may have a look at Getting started with Smarty
This theme configuration property has come with version 5.1.2: SW-12782 - Add theme config property to configure inheritance position · shopware/shopware@163860e · GitHub
You can change the var in your Theme.php to true or false: shopware/Theme.php at 5.1 · shopware/shopware · GitHub
