PhpStorm Shopware plugin shortcut 'swconfig' does NOT work
In PhpStorm I’ve installed the plugin “Shopware”, and it works for most of the cases.
But when I tried to use the Live Template shortcut swconfig in PhpStorm for calling up some default configurations of Shopware, this shortcut did NOT exist/work at all.
What’s the problem? Should I do some other configurations to enable this shortcut in the plugin?
I hope someone can help me in this.
Same here…
Hello @Sentry‍,
this is not related to the Shopware Plugin, this is simply a PHPStorm Live template configuration.
You could just set it up yourself under Settings > Live templates. A guide for this can be found here.
Yet I wonder: What makes you think this ‘swconfig’ is part of the Shopware Plugin? Is it mentioned at some place?
Just want to avoid further confusion.
Kind regards,
Patrick  Shopware
[@Patrick Stahl](http://forum.shopware.com/profile/1869/Patrick Stahl „Patrick Stahl“)‍ thank you for your answer.
I‍t is mentioned at the Shopware Developer Basic Course in the shopware academy as well as on udemy. On udemy every chapter has a Q&A-Section, there the tutor answered this question already and provided the live templates.
Chech the answer on stackoverflow.
