Hallo @Michael Telgmann,
Könnten Sie zu mir erklären warum diese Exeption kommt beim jeden Anruf.
hier ist ein Beispiel:
SwagPaymentPayPalUnified\PayPalBundle\Components\Webhook\WebhookException: The specified event is already registered. in /custom/plugins/SwagPaymentPayPalUnified/PayPalBundle/Services/WebhookService.php:28 Stack trace:
#0 /custom/plugins/SwagPaymentPayPalUnified/PayPalBundle/Services/WebhookService.php(42): SwagPaymentPayPalUnified\PayPalBundle\Services\WebhookService->registerWebhook()
#1 /custom/plugins/SwagPaymentPayPalUnified/Controllers/Frontend/PaypalUnifiedWebhook.php(55): SwagPaymentPayPalUnified\PayPalBundle\Services\WebhookService->registerWebhooks()
#2 /engine/Library/Enlight/Controller/Action.php(183): Shopware_Controllers_Frontend_PaypalUnifiedWebhook->preDispatch()
#3 /engine/Library/Enlight/Controller/Dispatcher/Default.php(478): Enlight_Controller_Action->dispatch()
#4 /engine/Library/Enlight/Controller/Front.php(228): Enlight_Controller_Dispatcher_Default->dispatch()
#5 /engine/Shopware/Kernel.php(188): Enlight_Controller_Front->dispatch()
#6 /vendor/symfony/http-kernel/HttpCache/SubRequestHandler.php(102): Shopware\Kernel->handle()
#7 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(453): Symfony\Component\HttpKernel\HttpCache\SubRequestHandler::handle()
#8 /engine/Shopware/Components/HttpCache/AppCache.php(261): Symfony\Component\HttpKernel\HttpCache\HttpCache->forward()
#9 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(238): Shopware\Components\HttpCache\AppCache->forward()
#10 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(255): Symfony\Component\HttpKernel\HttpCache\HttpCache->pass()
#11 /engine/Shopware/Components/HttpCache/AppCache.php(143): Symfony\Component\HttpKernel\HttpCache\HttpCache->invalidate()
#12 /vendor/symfony/http-kernel/HttpCache/HttpCache.php(181): Shopware\Components\HttpCache\AppCache->invalidate()
#13 /engine/Shopware/Components/HttpCache/AppCache.php(113): Symfony\Component\HttpKernel\HttpCache\HttpCache->handle()
#14 /var/www/clients/client1/web1/web/shopware.php(122): Shopware\Components\HttpCache\AppCache->handle()
#15
ist das normal ?? wenn nein was kann das Problem sein?
danke.
VG,
Tel.: +49 755 - 183 990 00 | E-Mail: info@enbit.de | Web: http://enbit.de/
