Hello,
I am trying to override the default values in the responsive theme. We have created our  own theme which extends the responsive theme. In our website I am trying to use the jquery image slider component that is included in the responsive theme. The default value of autoSlide is set to false and I would like to change this to true so that the images slide automatically after every 5 seconds.
I tried the following ways to do this:
- Using the override method.
Below is the new plugin that I have created ( jquery.image-slider.js) and added to themes / Frontend / MyTheme / frontend / _public / src / js /. I also added
protected $javascript = [
‚src/js/jquery.image-slider.js‘
to my Theme.php file. My plugin file looks like this:
;(function (, window) {     'use strict';     .overridePlugin(‚swImageSlider‘, {
      defaults: {
          autoSlide: true
      init: function () {
          var me = this;
          me.superclass.init.apply(this,arguments);
I also tried this in my plugin file:
$.plugin(‚swImageSlider‘, {
defaults: {
‚autoSlide‘: true
I added the below code to my html file
These options did not work. Can somehow guide me as to what I am doing wrong.
Thak you in advance.
