OpenSSLKey Xampp
Hallo Leute,
ich versuche gerade Shopware 6 auf Xampp in Windows zu installieren. Leider erhalte ich folgende Fehlermeldung
Slim Application Error
Type: TypeError
Message: openssl_pkey_get_details() expects parameter 1 to be resource, bool given
File: C:\xampp\htdocs\sw6\public\recovery\install\src\Service\JwtCertificateService.php
Line: 30
Trace
#0 C:\xampp\htdocs\sw6\public\recovery\install\src\Service\JwtCertificateService.php(30): openssl_pkey_get_details(false)
#1 C:\xampp\htdocs\sw6\public\recovery\install\src\app.php(322): Shopware\Recovery\Install\Service\JwtCertificateService->generate()
#2 [internal function]: Closure->{closure}(Object(Slim\Http\Request), Object(Slim\Http\Response), Array)
#3 C:\xampp\htdocs\sw6\public\recovery\common\vendor\slim\slim\Slim\Handlers\Strategies\RequestResponse.php(41): call_user_func(Object(Closure), Object(Slim\Http\Request), Object(Slim\Http\Response), Array)
#4 C:\xampp\htdocs\sw6\public\recovery\common\vendor\slim\slim\Slim\Route.php(356): Slim\Handlers\Strategies\RequestResponse->__invoke(Object(Closure), Object(Slim\Http\Request), Object(Slim\Http\Response), Array)
#5 C:\xampp\htdocs\sw6\public\recovery\common\vendor\slim\slim\Slim\MiddlewareAwareTrait.php(117): Slim\Route->__invoke(Object(Slim\Http\Request), Object(Slim\Http\Response))
#6 C:\xampp\htdocs\sw6\public\recovery\common\vendor\slim\slim\Slim\Route.php(334): Slim\Route->callMiddlewareStack(Object(Slim\Http\Request), Object(Slim\Http\Response))
#7 C:\xampp\htdocs\sw6\public\recovery\common\vendor\slim\slim\Slim\App.php(515): Slim\Route->run(Object(Slim\Http\Request), Object(Slim\Http\Response))
#8 C:\xampp\htdocs\sw6\public\recovery\install\src\app.php(153): Slim\App->__invoke(Object(Slim\Http\Request), Object(Slim\Http\Response))
#9 [internal function]: Closure->{closure}(Object(Slim\Http\Request), Object(Slim\Http\Response), Object(Slim\App))
#10 C:\xampp\htdocs\sw6\public\recovery\common\vendor\slim\slim\Slim\DeferredCallable.php(43): call_user_func_array(Object(Closure), Array)
#11 [internal function]: Slim\DeferredCallable->__invoke(Object(Slim\Http\Request), Object(Slim\Http\Response), Object(Slim\App))
#12 C:\xampp\htdocs\sw6\public\recovery\common\vendor\slim\slim\Slim\MiddlewareAwareTrait.php(70): call_user_func(Object(Slim\DeferredCallable), Object(Slim\Http\Request), Object(Slim\Http\Response), Object(Slim\App))
#13 C:\xampp\htdocs\sw6\public\recovery\common\vendor\slim\slim\Slim\MiddlewareAwareTrait.php(117): Slim\App->Slim\{closure}(Object(Slim\Http\Request), Object(Slim\Http\Response))
#14 C:\xampp\htdocs\sw6\public\recovery\common\vendor\slim\slim\Slim\App.php(405): Slim\App->callMiddlewareStack(Object(Slim\Http\Request), Object(Slim\Http\Response))
#15 C:\xampp\htdocs\sw6\public\recovery\common\vendor\slim\slim\Slim\App.php(313): Slim\App->process(Object(Slim\Http\Request), Object(Slim\Http\Response))
#16 C:\xampp\htdocs\sw6\public\recovery\install\index.php(51): Slim\App->run()
#17 {main}
Warning: openssl_pkey_export_to_file(): cannot get key from parameter 1 in C:\xampp\htdocs\sw6\public\recovery\install\src\Service\JwtCertificateService.php on line 27
Kennt jemand dieses Problem? Wie kann man es umgehen?
Danke
Liebe Grüße
Servus.
Habe es gerade auch. Werde es auch heute nicht mehr lauffähig bekommen, aber um dich an meiner Suche teilhaben zu lassen. Scheint ein reines win Problem von PHP zu sein.
Also sofern in der php config das openssl module einkommentiert ist, liegt es vermutlich an den nicht eingetragenen bzw falschen (und/oder doppelt vergebenen) Umgebungsvariablen unter win.
https://stackoverflow.com/a/3607026
Kannst ja mal Rückmeldung geben falls du noch zu was kommst.
lg
Habe das selbe Problem. Dabei ist es bei mir komplett unabhängig welche php Version ich nehme also. Habe es getestet mit Version 7.2 sowie 7.3. Installiert wurde lokal mit xampp.
Beides mal die selbe Meldung.
Wäre schön wenn hier wenigstens mal der Support antwort und Lösung geben würde.
Unabhängig von dem Problem solltet ihr auf jeden Fall Linux/MacOS nutzen, da ihr immer wieder in Probleme laufen werdet.
Eine Unix-Basis ist hier Pflicht.
@jaye schrieb:
Servus.
https://github.com/bunq/sdk_php/issues/102
lg
vielen Dank!
Die Anleitung bei Stackoverflow hat funktioniert für mich :slight_smile:
@Moritz
Leider steht mir in diesem Fall keine Unix Basis zur Verfügung…
