I have installed Shopware 6 (my provider had a plug in doing it), and I start to understand how to use it, and I also manage to get some of the function into page.
My problem is that I do not understand how to get the multiple language to work.
In the backend, one can define the url for the different languages. So I set up
myurl/test (english version) The normal installation which also works.
myurl/test/de (german version)
myurl/test/se (swedishversion)
At the moment the complete installation is in my folder
www.xxxxxxxxxx.com/test
But how do I make it work? Can I simply copy-past all content from the main folder to the „language folders“ myurltest/de myurl/test/se?
Or is is only some specific folders?
